Starter replaced, still won't start-run
Old 11-11-13, 08:41 AM
barrynwatt
barrynwatt's Avatar
Default Starter replaced, still won't start-run
I have a 1994 lexus ls400 & had the starter replaced & now i try to start it ,it start & shuts back off as if its out of gas . I was thinking it was the computer, before the starter went out i could be driving & when i pressed the gas pedal hard its like it would fall on its face, anyone else have had these issues?
Old 11-11-13, 12:07 PM
billydpowe
billydpowe's Avatar
try doing a search or read the stickies at the top of the forum...
Old 11-16-13, 04:18 PM
RA40
Super Moderator
RA40's Avatar
The most likely is that during the starter replacement some connector has been removed and not put back properly. Check all those connections around the intake plenum and throttle body.
Old 11-18-13, 11:52 AM
barrywatts
barrywatts's Avatar
Ok will check that , also think it maybe the crank sensor, i put a used one in it started and ran about 5 miles & started doing the same thing so I'm about to tfy a new crank sensor
Old 01-04-14, 01:54 AM
shanjam
shanjam's Avatar
try crank sensor dirty clean,or replace
Old 01-04-14, 04:13 PM
cobalt91
cobalt91's Avatar
Check the harness leading to the crank sensor for damage. The clips get old and break. Then the wires rub on the drive belt.
Old 01-04-14, 08:25 PM
stephen18
stephen18's Avatar
are there any codes stored?
Bylan
06-18-19 04:39 PM
PickupStix
06-19-16 11:12 AM
sj408
Performance & Maintenance
08-17-12 11:16 AM
92lexus
Maintenance
07-23-08 01:23 PM
Quick Reply: Starter replaced, still won't start-run
