90' LS400 crank angle sensor bad??
Old 08-18-13, 07:51 AM
LScowboyLS
LScowboyLS's Avatar
Wal-mart and Amazon have this one for $17 and it is a good multimeter
Old 08-18-13, 08:31 AM
MattLS400
MattLS400's Avatar
these threads are really informative with everyone's feedback . what are the symptoms of a bad crank angle sensor in a 120k 1994 Lexus LS400 ?
Old 08-18-13, 08:40 AM
Gene01
Gene01's Avatar
LScowboy has identified a winner! I especially like the battery test functions (tests under load rather than open-circuit)
Old 08-18-13, 09:31 AM
LScowboyLS
LScowboyLS's Avatar
here is the meter here is the meter
I find myself using most of the time!
made in Japan! - like your Lexus
Old 08-18-13, 09:19 PM
johnnyg66
johnnyg66's Avatar
That pen one looks nice. Still like my Fluke.
Old 08-19-13, 09:14 AM
daveskates
daveskates's Avatar
that pen one is pretty cool and i'll pick one up on my lunch break !
hopefully can get the car going soon i hate not being able to drive it
Old 08-19-13, 06:02 PM
daveskates
daveskates's Avatar
So until the multimeter comes in the mail there's not much I can do. I did go to the junkyard a second time and pull another CAS just to see if my CAS went bad, also I pulled it completely out to the point where I didn't have to cut and re soldier wires, it cranked and cranked, IT almost turned over once though and then the same deal. Here is a picture of the one I had to soldier the wires on, also is this metal piece that holds the wires a type of ground? on all the ones i've seen it has a tiny bit of wire that sticks out, not sure if it's some type of ground or not, does anyone know?
Old 08-19-13, 06:46 PM
LScowboyLS
LScowboyLS's Avatar
found it $5 cheaper
Old 08-20-13, 11:01 AM
timmy0tool
timmy0tool's Avatar
hmm that metal piece could be a ground pin. did your junkyard replacement have that pin too?
Old 08-20-13, 12:02 PM
deanshark
deanshark's Avatar
That metal piece looks like it just holds the wire in place so it wont be flopping around and get chewed up by something. I dont recall seeing one on my car anywhere near the crank sensor. Maybe it was a 90-92 thing. Where was it bolted on?
Old 08-20-13, 01:51 PM
LScowboyLS
LScowboyLS's Avatar
daveskates - a lot of your questions are answered in the factory shop manual
Old 08-20-13, 01:59 PM
daveskates
daveskates's Avatar
yep sure did, i looked at various years early and later model LS400's and all the CAS's looked the same
Old 08-20-13, 02:03 PM
daveskates
daveskates's Avatar
i suppose it's time to do some reading then it is going to be a bit overwhelming i feel like but thank you sir
Bankswood
Performance & Maintenance
02-16-16 01:57 PM
whtricsc40
IS - 1st Gen (2001-2005)
20
10-10-12 08:26 PM
want sc300
06-25-11 03:57 PM
99svtvenom
01-16-11 05:17 AM
R.G.
RX - 1st Gen (1999-2003)
01-25-09 07:45 AM
Quick Reply: 90' LS400 crank angle sensor bad??
