Humming noise on 99 LS400
Old 08-14-13, 03:04 AM
ItsMiles
ItsMiles's Avatar
Default Humming noise on 99 LS400
Tried doing some searches here and I couldn't find anything... Well this problem started this morning. Basically, when I started the car, I heard a "loud humming" I thought it might have been the engine and the belts still cold... But when the engine warmed up I still noticed the humming. When I drive I can hear the humming. The sound matches the revs in the engine... When Rpm drops, humming drops, when rpm goes up, the humming follows, you get the picture...
I'm stumped. I checked engine oil, it's fine. Thought it was transmission fluid, but that's fine. Checked power steering fluid, and that's good... It's too dark to check much else right now, and in planning to check in the morning, but I believe it can be a belt issue... Car has 97k on it. With the timing belt and water pump already replaced by past owner...
Any ideas guys??
Old 08-14-13, 03:12 AM
ItsMiles
ItsMiles's Avatar
No vibrations/ shaking while driving, sound doesnt change while turning, doesn't go away when i let off gas...
Old 08-14-13, 04:55 AM
Lavrishevo
Lavrishevo's Avatar
I would guess a pulley or tensioner. Did you have the timing belt tensioner replaced with the belt? There is one for the serpentine belt too.
Old 08-14-13, 07:06 AM
ItsMiles
ItsMiles's Avatar
This is what I was thinking too.. I'm hoping this isn't what it is...
Old 08-14-13, 07:34 AM
Twista4004
Twista4004's Avatar
maybe its not seated properly. wouldn't hurt to take a look.
Old 08-14-13, 10:57 AM
RA40
Super Moderator
Senior Moderator
RA40's Avatar
Take the tension off the serpentine belt and spin the top idler. Cycle the A/C to verify compressor clutch operation.
Old 08-14-13, 01:06 PM
ItsMiles
ItsMiles's Avatar
http://i710.photobucket.com/albums/w...F442E50D32.mp4
Here's what it sounds like... You might have to turn up the speakers to get a really good listen to the humming...
I'm thinking its coming from the intake... But I might be mistaken... Doesn't seem like it's coming from the serpentine belt... The sounds is coming from somewhere in between the power steering and water pump.. That's my thought...
Old 08-14-13, 01:38 PM
snoop562
snoop562's Avatar
i read a thread where the humming came from the electronics on the throttle body. might be worth taking a look.
Old 08-14-13, 01:45 PM
ItsMiles
ItsMiles's Avatar
You know what, that's another thing I was thinking... Because it does sound like it could also be coming from the plastic intake pipe that connects to the Throttle body...
If it is the electronics on the throttle body, how would I go about checking that? Or repairing that?
Old 08-14-13, 01:55 PM
snoop562
snoop562's Avatar
i would have the car in park with the engine running and have someone rev it while your under the hood listening. i think the part was the throttle position sensor and it was on the right side of the throttle body.
Old 08-14-13, 02:49 PM
ItsMiles
ItsMiles's Avatar
Well I I did that in the video... Revving it myself from under the hood, but like I said, I don't think this idea about the TPS being too far off.. That or the Pulley for the AC..
Old 08-14-13, 03:10 PM
LScowboyLS
LScowboyLS's Avatar
you can narrow down the possibilities very quickly by simply removing the serpentine belt (a one minute job) and then crank the car and also rev it (this is perfectly safe, you just won't have power steering, alternator charging, A/C, etc.) and then note if the hum goes away
reinstalling the serpentine belt is about a 2 minute job once you get the hang of it, but if you have never done it before, it could take 15
Old 08-14-13, 04:03 PM
ItsMiles
ItsMiles's Avatar
So just remove the entire belt?
Old 08-14-13, 05:56 PM
LScowboyLS
LScowboyLS's Avatar
yes
if the noise goes away, then it is something the belt was driving - i.e. A/C clutch pulley bearing, power steering, idler, tensioner, alternator, etc.
if the noise is still there with belt off, then you just quickly and easily eliminated all of those items mentioned above!
Old 08-14-13, 06:54 PM
deanshark
deanshark's Avatar
Sounds like a pulley to me. But hard to hear 100%. Like Cowboy said, take the belt off and listen if you dont hear it. I'm guessing the tensioner pulley, the bearings are a common problem. With the belt off (and car not running) reach in and try to wiggle and spin the pulley, see if it wobbles or makes any type of scraping noise.
Quick Reply: Humming noise on 99 LS400
