rear bass speaker ls400
Old 08-11-13, 07:35 PM
mbz560
mbz560's Avatar
Default rear bass speaker ls400
i've got a 92 ls400. i took the nakamichi rear speaker from a 92 sc400. i thought it would just wire up into my ls400. i took the wires from the old panasonic speaker and adapted it to the nakamichi speaker so it would just hook up. but the speaker doesn't play. it barely makes a scratching noise. does it matter if the nakamichi is 5ohms and the panansonic is 2 ohms.
what am i doing wrong? thanks for the help
Old 08-11-13, 08:14 PM
dc893
dc893's Avatar
I am not an expert by any means on audio equipment. I do believe that will not work. Ohms are very important. I made a very rookie mistake several years ago. I had two twelves hooked up to an amp pushing the wrong amount of ohms. Fried the amp in a couple days. I would disconnect that speaker or you may possibly destroy the factory amp.
Old 08-12-13, 06:56 AM
python
python's Avatar
I have an extra one in my car I do not use...its a Rockford fosgate punch 2
http://www.sonicelectronix.com/item_...nch-P2D48.html
I would be glad to sell it to u for 40 plus shipping...I also have some door speakers..but I modified the front boxes to fit bigger speakers so they are 5.25
they are alpines r series
http://www.crutchfield.com/p_500SPS6...8016065&awdv=c
those I want 80 plus shipping
Old 08-12-13, 10:18 AM
denverdog
denverdog's Avatar
ohms = resistance to electrical flow. five ohms is 2 and a half times the resistance of two hms. it thinks its getting a very minimal signal.
Old 08-12-13, 04:11 PM
mbz560
mbz560's Avatar
Default forgot to add
i've got the amp that powers the nakamichi system. do you think that would be a plug and play situation? i don't anything about electronics so when you talk about ohms what is it i need to do to make this speaker work with the pioneer system. if the nakamichi amp plugs in where the old amp is do you think that would work? any help/advice is appreciated. thanks
Old 08-14-13, 03:53 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
no. nowhere near plug and play.
Please stop trying to frankenstein 20 year old audio sytems together. step back, do some research, then think about what it is you're trying to achieve.
jonathancl
08-31-06 09:39 AM
hardhat
06-23-05 10:31 AM
hoang76
11-14-02 05:34 PM
Quick Reply: rear bass speaker ls400
