Thermostat Housing Stud/Bolt
Old 08-04-13, 11:18 PM
Modrod
Modrod's Avatar
Default Thermostat Housing Stud/Bolt
I was putting in a thermostat on my friends 96 LS400 and when I was tightening the bottom nut down the stud snapped. Is it possible to replace just the stud/bolt or do I need to replace the whole housing?
Old 08-05-13, 12:39 AM
LScowboyLS
LScowboyLS's Avatar
you will need to replace the whole housing, but junkyard is fine on this part if it is not corroded, and in nice condition (about $2-$5 at the local pull-a-part)
how to keep this from happening next time:
1. use a torque wrench like you are supposed to on all fasteners under the hood
2. don't have a torque wrench and in a bind? - on these small 10mm fasteners, place the head of the ratchet in your palm and tighten it up (don't touch the ratchet handle) - I don't care how much of a bad-*** you are, you cannot get enough torque to snap a fastener this way, but you can get enough torque to get a good seal!
Old 08-05-13, 02:17 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
this is incorrect.
You can replace just the stud, the part number is 92122-B0822, there are 2 of them that hold the water inlet to the housing. (1996 LS400)
Old 08-05-13, 07:06 AM
Modrod
Modrod's Avatar
Originally Posted by PureDrifter
this is incorrect.
Cool, thanks.
Side note: I did use a torque wrench but it was a crappy rental from Autozone and the lock was faulty. I realized this too late, obviously.
Old 08-05-13, 12:31 PM
LScowboyLS
LScowboyLS's Avatar
this is incorrect.
nah, I realize you can technically replace just the stud, but sometimes the remaining half can be difficult to extract and the threading in the hole where the over-torque situation occurred is often damaged, the strength of the entire unit can often be compromised due to fissures and metal fatigue.
best to just get another undamaged housing at the junkyard as I previously stated, this is not a rare or expensive part
"a word to the wise......"
bb430
03-17-15 03:02 PM
dairon
Performance
09-08-14 01:24 AM
Gumart1
03-20-13 01:16 AM
whooper20
Performance & Maintenance
08-21-11 09:31 AM
LEXBERG
08-03-03 01:39 AM
Quick Reply: Thermostat Housing Stud/Bolt
