I need to find vss wire for double din Navigation?
#32
Repost
How, and where, did you mount your amplifier?
The amp is not mounted yet. Its just laying in the trunk right now hooked to a second AGM battery. Keep watching the thread and I will show it mounted.
How did you deal with the amp turn-on wire?
It is hooked up to the remote wire on the back of the Jvc.
How did you power your head unit?
I used a wiring diagram and hard wired everything. It is a lot easier than you'd think.
#35
Battery BLUE/YELLOW (+) RADIO HARNESS
Accesory GRAY (+) RADIO HARNESS
Ground BROWN (-) RADIO HARNESS
Illumination GREEN (+) RADIO HARNESS
Power Antenna BLACK/RED (+) RADIO HARNESS
You strip the wire a little or use quick connects. This is not the plug but you do the same thing with the radio factory plug.
-Strip wire with blade
-Wrap the yellow wire coming from the double din around the BLUE/YELLOW wire on the factory plug and wrap it very tight with electrical tape.
-Gray goes to the red double din wire
-Brown goes to the black double din wire. There are 2 brown wires, use the one on the end of the plug
-Green goes to the orange/white double din wire
-BLACK/RED goes to whatever double din wire is labeled power antenna
If you still don't understand take it to a shop!
#37
l have the 97 model. I don't know if there is a different diagram or if they make a wire harness kit for your car?
#38
*EDIT* - Those wires you listed don't seem to change with my car. They're still the same colors and thank you very much for that heads up!
orion603
05-28-18 03:16 PM
vicious
13
12-05-11 09:14 AM
Parker Gen
04-19-09 05:31 PM
aparker813
12
06-10-08 08:52 PM
