redrilled style 95's
I've read that these need adapters in order to fit over the brakes on a 98-up brakes. Question, will 10mm clear the calipers? Or is 15mm needed? Also are the adapters only needed to clear the fronts? Or will they be needed in the rear also?
TIA
TIA
Forum Administrator
I think folks will need more info like the wheel disk fittment and possibly offset, pic of the wheel design also helpful.
Super Moderator
FWIW from memory: somebody in the past had redrilled 95's and it needed a 15mm in front to clear. Easiest to verify is to put them on the car to see. Those running adapters on the factory drilling cleared anyway but it was pretty aggressive.
One discussion here:
https://www.clublexus.com/forums/ls4...on-a-ucf1.html
Custom spacers/adapters:
http://www.motorsport-tech.com/wheel_adapters.html
