Sensor on Bottom of Intake Manifold
Old 05-15-13, 01:15 PM
s1haro187
s1haro187's Avatar
Default Sensor on Bottom of Intake Manifold
Can some one tell me what this sensor is called? I need a new connector for it.
[IMG][/IMG]
Old 05-15-13, 03:00 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
idle air controller iirc.
Old 05-16-13, 06:46 AM
LScowboyLS
LScowboyLS's Avatar
most junkyards on ebay call them the idle air control valve (IACV)
the connector is one you can find on many other 90's Toyota models, and the connector was used on other components in other Toyota models besides just on the IACV - take the damaged connector with you to the pull-a-part junkyard and compare
if your IACV should fail (fairly common) you can rebuilt it with new bearings or else use my poor man's idle air control valve, in a pinch
Old 05-16-13, 10:44 AM
s1haro187
s1haro187's Avatar
alright thanks, I appreciate it. I'm pretty new to the 1UZFE, But I love it and plan on doing alot to my LS400. Does any one know where I can get a connector for the IACV online or in Texas? mine completely broke. I tried junkyards in my area but they all suck and dont even have LS400's
Old 05-16-13, 01:45 PM
LScowboyLS
LScowboyLS's Avatar
two good choices:
www.car-part.com
www.ebay.com
find someone selling an idle air control valve from years 90-97 (there are dozens of these out there)
then ask the seller if he has the "pigtail" for it
PS - if you had read my previous post more carefully, you would have noticed that I previously stated that the same connector is used on many parts of many Toyota vehicles, not just LS400's - and Toyotas in junkyards are in every town in America!
Old 05-17-13, 07:34 PM
s1haro187
s1haro187's Avatar
So I just got the pigtail from a 91 LS400 but the colors of the wires are a little different. Does any one have a wiring diagram for the IACV pigtail?
Old 05-18-13, 09:10 AM
LScowboyLS
LScowboyLS's Avatar
I have the wiring diagram around here somewhere, but not sure why you need it if you still have the old broken connector with it's wires attached - do you have an ohm-meter?
I will dig out the diagram
Old 05-18-13, 01:43 PM
s1haro187
s1haro187's Avatar
Thanks I appreciate it. I dont have the old connector, i completely broke apart. Yes I have a ohm meter.
Old 05-18-13, 03:14 PM
LScowboyLS
LScowboyLS's Avatar
what year is your LS400?
Old 05-18-13, 05:43 PM
s1haro187
s1haro187's Avatar
its a 95 Ls400
Old 05-18-13, 06:30 PM
LScowboyLS
LScowboyLS's Avatar
my girlfriend has reorganized my stuff and I am currently unable to locate my wiring diagrams, however the real Lexus factory wiring diagram is dirt cheap and a great thing you will be glad you have for years to come! - here is where to order it
redzeppelin
07-09-16 10:22 PM
Pescao
RX - 1st Gen (1999-2003)
08-28-09 07:02 AM
cgholson
07-17-08 05:28 PM
palaka
05-23-08 05:39 PM
Quick Reply: Sensor on Bottom of Intake Manifold
