help - leak and squeaks
Well im new here so hello everybody, i was wondering if i could get some help. My 94 lexus ls400 has a leak which i cnt locate, my belts sqeak like crazy, any suggestions how to solve this.
im like half sure its the power steering fluid that is leaking, i really hate driving my car because the sqeak is soooo loud
Sqeaking belts do suck. But, you need to do some research on here and visually check under the hood. Clean everything and drive it like ^^^ stated above. These cars are known for powersteering leaks, and there is a ton of info on the subject. Most of the time it will be faster for you to search for answers rather than wait for someone on here to reply.
Is your belt making noise or is it the pump itself?
squeaky belts mean either there is poor tension or there is an obstruction. if you are loosing power steering fluid, you will dry out the power steering pump which will cause noises. how is the power steering fluid level? oil level?
power steering and oil fluid can sometimes be mistakes as each other. best way is to check all your levels and narrow it down. don't delay on a power steering leak, it can ruin the alternator sitting below it!
Super Moderator
Welcome to Club Lexus.
How many miles on car? With a leaking P&S pump that needs to be fixed ASAP. A dead alternator is downstream of the pump and that is $ to fix.
Along with the suggestions above, have a look through this FAQ for additional info. Though listed as 95+, the first gen and second share many similarities that are applicable.
https://www.clublexus.com/forums/ls4...questions.html
Make certain you put Dexron ATF in the P/S system, and NOT "power steering fluid" like most people do. The so called "P/S fluid" is for Ford/Chrysler/GM stuff, not for Toyotas!
AzHotLS
12
09-03-14 10:49 PM
