New shoes! (need some advice)
Old 05-05-13, 06:37 PM
usoff89
usoff89's Avatar
Default New shoes! (need some advice)
I picked up some new wheels fot the LS. The tires you see in the pics are garbage. I still need to switch my tires from my old wheels. This was just a test fit to see how bad I need to roll/pull the fenders.
Spec's of the setup that will be on the car. (not the tires in the pics)
18x9F (225/40)
18x10R (245/40)
The tires you see in the pics are 255/40F and 275/40R. And the rear fender is resting on the tire in the pic. Oh, and I will be painting the red center caps black.
What do you guys think? After I switch the tires, will I have to do a mad pull or will a slight roll get it done? It's just natural camber right now.
Attached Thumbnails New shoes! (need some advice)-img_7304.jpg   New shoes! (need some advice)-img_7305.jpg   New shoes! (need some advice)-img_7307.jpg   New shoes! (need some advice)-img_7308.jpg   New shoes! (need some advice)-img_7310.jpg
Old 05-05-13, 06:40 PM
usoff89
usoff89's Avatar
another angle
Old 05-05-13, 06:44 PM
sha4000
sha4000's Avatar
Is that Plasti- dip or primer on the car?
Old 05-05-13, 07:41 PM
usoff89
usoff89's Avatar
Neither, it's a single stage paint. It's super dirty in the pics. Had to drive down a long dirt road to pick up the wheels.
Old 05-05-13, 08:23 PM
dengman
dengman's Avatar
depends on the offset on the wheels. those tires in the pic would probably fit with a pull and more camber.
Old 05-06-13, 04:29 AM
Rasimmo
Rasimmo's Avatar
I like those better than the old ones!
Old 05-06-13, 10:19 AM
usoff89
usoff89's Avatar
The offsets are 12F and 30R. Thats the only thing I found on the wheels. I want to have a small stretch on the tires anyway. I'm going to get the tires on and then do another test fit. I might be able to get away with just a shave in the rear?
Old 05-06-13, 11:01 AM
akitomk3
akitomk3's Avatar
For the rears i think you should be fine with a roll and maybe a slight pull for 245 . Hard to tell unless you get those tires on and then mod the fenders to fit.
Old 05-06-13, 11:14 AM
adamls2
adamls2's Avatar
225 or even a 215 in the front, 245 or 235 in the back should do the trick, with shaving the rears and rolling the fronts. Do that then go from there!
Old 05-06-13, 01:26 PM
timmy0tool
timmy0tool's Avatar
this will take minimal fender work to fit! just get smaller tire sizes and they will work. i'm guessing 225 front and 235 rear!
Old 05-06-13, 02:48 PM
usoff89
usoff89's Avatar
I will be running a 225 up front, but I'm going to try and run the 245's I already have in the rear. I have a stack of 245's in the garage!
I'm going to mount one of my spare 245's on a rear rim wed and see how it fits then. I'm going to do a slight shave on the rear tonight and get those little sqaure tab sections cut off the fender lip.
Old 05-06-13, 03:17 PM
adamls2
adamls2's Avatar
Leave the 245's for the burnouts
Old 05-06-13, 03:42 PM
usoff89
usoff89's Avatar
lol, I still have some extras.
Old 05-06-13, 08:35 PM
Rasimmo
Rasimmo's Avatar
is that Adam chuckling after you burnout? lol
Posted from ClubLexus.com App for Android
Old 05-06-13, 08:37 PM
Rasimmo
Rasimmo's Avatar
I can't get mine to break loose..
Quick Reply: New shoes! (need some advice)
