Need help again ASAP ( will these wheels fit 1996)
Old 05-05-13, 05:19 AM
DougJoseph
DougJoseph's Avatar
Default Need help again ASAP ( will these wheels fit 1996)
Hey guys I have a 2nd gen 1996 Toyota Celsior/LS400 and I have the chance to buy some nice 19's just need to know if they'll fit.
The fitment is 19x8 19x9.5 with an et20 offset all around. Will this fit good one my Celsior?
Thanks!
Old 05-05-13, 05:24 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,128 Likes on 1,298 Posts
https://www.clublexus.com/forums/ls4...eel-setup.html start here.
Old 05-05-13, 05:36 AM
DougJoseph
DougJoseph's Avatar
Ya I was gonna try but I just dont overly have time to look through pages and pages I'm up north Alberta working at the moment seems like I never have time for anything lol
Old 05-05-13, 06:13 AM
DaveGS4
Forum Administrator
DaveGS4's Avatar
Helping yourself is usually a lot faster if this is 'asap' vs waiting for someone to answer.
Make sure to confirm the bolt pattern as well.
Old 05-05-13, 06:02 PM
DougJoseph
DougJoseph's Avatar
There 5x114.3
Old 05-07-13, 02:03 PM
93socal2jz
93socal2jz's Avatar
Well instead of looking thru tons of pages of wheel set-ups ill give my opinion, since it seems the other guy is too lazy to help you lmao smh moderators
I have 19x10+12 19x11+12 on my 96 and i have a slight roll in the back and a decent one in the front, so im gonna go ahead and say as long as u run like a 215-35/40-19 tire and a 225-35/40-19 tire you should be fine
the difference in the sidewall height 35/40 is based on how you want the ride to be and how much meat u like on the tires
hope this helps
Old 05-07-13, 02:24 PM
OKSTANCE
OKSTANCE's Avatar
those should fit great but you mighttt rub a tiny bit with the rears
i know running a 19x9.5+45 rear on my 93 barley cleared the stock fenders
you might have to shave a tiny bit off but nothing major
Old 05-07-13, 04:31 PM
timmy0tool
timmy0tool's Avatar
in general, those will fit. 90-94 cars have smaller fenders compared to 95-00.
in addition you have to consider if the car is lowered and how low, plus your tire sizing, PLUS the spoke design if it will allow your brake calipers to clear. lots of extra info is needed before we can give a definite answer.
Old 05-07-13, 05:35 PM
DaveGS4
Forum Administrator
DaveGS4's Avatar
hope this helps
Before you call me lazy and "smh"....I wouldn't hazard a guess because I simply don't personally know the answer. I don't own that car, never have (had a 98 and 05 LS) and am not a wheel fittment expert so I tried to help the guy find his answer on his own as best I could. The answer is there if he took the time too look since he needed it ASAP
Please don't publicly put me down for trying to help. Not cool.
Pm me if you want to discuss further please.
Old 05-07-13, 06:19 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
hope this helps
looking at your pics you have a pretty solid pull in the front, not just a roll. Mild pull in the rear.
OP should have searched, if he had he would have found that with his specs and relatively narrow wheels he can get away with a roll/shave in the front and rear with full sized tires, no stretch needed.
Old 05-08-13, 04:47 AM
DougJoseph
DougJoseph's Avatar
I personally would like to get away with not pulling or rolling fenders but if I gotta do it I will. Also I like the look of stretched tires on rims, So saying that what size tires would be ideal to stretch on the rims? I'll try and get some pics of the rims to upload asap!
Thanks
Attached Thumbnails Need help again ASAP ( will these wheels fit 1996)-3f0cb170-fb60-45a9-9a24-204a88c68a21-1211-00000119d4c121c3_zps5375dea7.jpeg
Old 05-08-13, 10:48 AM
timmy0tool
timmy0tool's Avatar
first you must answer the question of how low you are going to be, if you plan to lower at all. it's hard to determine a fitting tire size before knowing how much clearance you have.
also i hope you considered if those will clear your front brake calipers.
Old 05-08-13, 05:00 PM
DougJoseph
DougJoseph's Avatar
It has the stock air ride and I'll probably just leave it stock. I think I'll have the Celsior up for sale soon anyways.
Old 05-08-13, 06:48 PM
PureDrifter
BahHumBug
you'll blow the bags right quick if you try to drive low on them.
Stretching for the hell of it and not because you actually need the clearance is going to look plain silly, and will likely cause people to laugh at you.
Old 05-08-13, 06:56 PM
usoff89
usoff89's Avatar
^^^^ Listen to PD! I like the look of stretched tires too, but I'm not going to stretch tires if I don't have any clearance issues. But hey, if your selling it anyway who cares, right?
Quick Reply: Need help again ASAP ( will these wheels fit 1996)
