Speedo issue
Old 04-25-13, 06:26 AM
diamondave
diamondave's Avatar
Default Speedo issue
I have seen a few forums on here about this but my issue seems to be a bit different. This part has happened a couple times when i first start driving in the morning. i will be about a mile from the house and my speedo wont be working. one or 2 taps or bumps on the dash and it works and no problems. my second issue is from time to time and its not very often i will look down at the cluster and it appears the lights got brighter as if they were dimmed. all these issues are during the day with lights off. any ideas of help would be helpful. thanks
Old 04-25-13, 06:30 AM
diamondave
diamondave's Avatar
it seems to be it might be a bad connection. 1996 Ls400 242K
Old 04-25-13, 09:14 AM
LScowboyLS
LScowboyLS's Avatar
I had this exact problem on my 96, and as unrelated and crazy as it may seem, the problem turned out to be bad ECU capacitors
Now my speedo is always working right! - No more slapping the dash!
Old 04-25-13, 10:20 AM
diamondave
diamondave's Avatar
i have seen dozens of posts about ecu caps. is there anyone that sells rebuilt ecus? i dont have the time or patience to do it myself and i cant send mine off anywhere as i cant be without my car.
Old 04-25-13, 10:26 AM
LScowboyLS
LScowboyLS's Avatar
no one I know rebuilds them correctly, they don't use the premium Japanese low-ESR caps that are the correct fix. - the best idea I know is to find a deal on a cheap one at a junkyard or ebay to use while you mail yours off to be fixed properly, if you can find who does it well. - then resell the spare on ebay for what you paid for it.
If you leave out the lower glove compartment, you can swap ECU's in about 5 minutes if you are good with a ratchet!
Old 04-25-13, 10:28 AM
diamondave
diamondave's Avatar
ok who do you recommend to rebuild them?
TRDmike
SC- 1st Gen (1992-2000)
16
05-21-11 05:41 AM
49er_Gurl
02-17-09 09:37 AM
lexdiamonz
05-18-08 09:23 PM
1UZFE
11-03-03 07:00 AM
navybean
10-23-02 01:42 PM
Quick Reply: Speedo issue
