1993 LS400 - Trying to wire my double din.
Old 04-19-13, 06:05 AM
JSC4
JSC4's Avatar
Unhappy 1993 LS400 - Trying to wire my double din.
Hello guys,
I am new in the LS400 community. I previously owned 2 SC400s. The last 1 I had caught on fire so I decided to switch over and bought a 1993 LS400.
I previously have a double din from the SC that I'd like to install on the LS. After hours of searching for a wiring DIAGRAM, all I found is this:
1993 Lexus LS400 Factory Radio Wiring Chart
Car Radio Battery Constant 12v+ Wire: Red
Car Radio Accessory Switched 12v+ Wire: Gray
Car Radio Ground Wire: Brown
Car Radio Illumination Wire: Green
Car Stereo Dimmer Wire: N/A
Car Stereo Power Antenna Trigger Wire: Black/Red
Car Stereo Amp Turn-On Trigger Wire: Pink/Blue
Car Stereo Amplifier Location: Right Side of the Trunk
Car Audio Front Tweeter Size: 1″ Tweeters
Car Audio Front Tweeter Depth: 1″
Car Audio Front Tweeter Location: N/A
Left Front Speaker Positive Wire (+): Green
Left Front Speaker Negative Wire (-): N/A
Right Front Speaker Positive Wire (+): Red
Right Front Speaker Negative Wire (-): N/A
Car Audio Front Speakers Size: 5 1/4″ Speakers
Car Audio Front Speakers Depth: 3″
Car Audio Front Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White
Left Rear Speaker Negative Wire (-): N/A
Right Rear Speaker Positive Wire (+): Yellow
Right Rear Speaker Negative Wire (-): N/A
Car Audio Rear Tweeter Size: 1″ Tweeters
Car Audio Rear Tweeter Depth: 1″
Car Audio Rear Tweeter Location: N/A
Car Audio Rear Speakers Size: 6 1/2″ Speakers
Car Audio Rear Speakers Depth: 3″
Car Audio Rear Speakers Location: N/A
Car Subwoofer Speaker Positive Wire (+): N/A
Car Subwoofer Speaker Negative Wire (-): N/A
Car Subwoofer Speaker Size: 8″ Subwoofer
Car Subwoofer Speaker Depth: 4″
Car Subwoofer Speaker Location: N/A
Now, its not exactly a diagram. I am trying to splice wires from my headunit into the factory wires but I couldnt make it work. Is this possible? I manage to do this on my own in the SC as I found an actual wiring diagram but I cant find any for the 1993 LS.
I did find a diagram for the 1996, Is this the same?
https://www.clublexus.com/forums/ls4...-diagrams.html
Thank you guys for your help !
Old 04-19-13, 12:30 PM
JSC4
JSC4's Avatar
This is the wiring harness from my double din. If someone can tell me where to splice them, that would be great. Also if you can provide picture/diagram, even better !
Old 04-19-13, 02:10 PM
dc893
dc893's Avatar
What about a wiring harness?
Old 04-19-13, 03:39 PM
JSC4
JSC4's Avatar
Looks like this is the way to go
Old 04-19-13, 05:07 PM
usoff89
usoff89's Avatar
Although I don't have a double din, I would think you could use the same cheap little wiring harness I got for my single din. Plugs right into the stock harness and everything is labeled. Then you splice your headunits harness into it. Takes all of about 15-20 mins. With the harness I got, you can't use the factory amp though. When you do the harness, it's much easier to do it out of the car and then just go plug it in when your ready to install. I would never recommend cutting/splicing your factory harness even for a radio.
Old 04-19-13, 07:31 PM
dc893
dc893's Avatar
Amazon.com: Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker: Car Electronics Amazon.com: Metra 70-1761 Radio Wiring Harness For Toyota 87-Up Power 4 Speaker: Car Electronics
http://www.beatsonicusa.com/beat-sonic-sla-20ad.html
There are a couple options out there to make life much easier. With the beat sonic you can retain the factory sub. With the metra you will lose the factory sub. That is the one I used in mine and it sounds just fine.
Laza1
07-20-24 01:43 AM
Barizpe
10-07-15 08:24 AM
jmac2k11
GS - 1st Gen (1993-1997)
10-14-12 09:12 PM
Kalogerus
01-01-12 01:30 PM
SSmith
SC- 1st Gen (1992-2000)
02-06-02 01:47 PM
Quick Reply: 1993 LS400 - Trying to wire my double din.
