Serpentine belt tension
Old 04-09-13, 10:58 AM
Lavrishevo
Lavrishevo's Avatar
Default Serpentine belt tension
While cleaning up my engine bay on my 99 I notice the serpentine belt seemed to have a little more play then I would have thought. The belt is probably original and there are no cracks or corrosion that I see. She only has 78,000 miles. How much play should the belt have when you push on it?
Old 04-09-13, 09:36 PM
DesertLS
DesertLS's Avatar
I just changed mine a few months ago. I believe there is an arrow above the tensioner pulley that shows the current tension. After installing a new belt, the arrow should line up with the first dash mark. If it is the original, or it hasn't been changed in a while, there will definitely be more play in the belt. The pulley itself could also be giving too much play but it is likely a worn out belt.
It is pretty inexpensive and quick to change the belt yourself. Lexls.com has a great tutorial.
mooseboy84
10-31-15 11:35 PM
erock202
Performance & Maintenance
02-09-15 02:00 AM
UDel
Maintenance
11-26-11 07:55 PM
rx7guy
04-29-09 12:27 PM
chloe
03-29-08 01:00 PM
Quick Reply: Serpentine belt tension
