Transmission mount issue
Old 03-12-13, 07:38 AM
Eds98LS
Eds98LS's Avatar
Default Transmission mount issue
I plan on replacing the trans mount during my next oil change but wanted to see if anyone else experienced weird vibrations with theirs?
I'll have a vibration that goes away as soon as I throw the car in neutral from drive; it will also lighten up when parked but is totally unnoticeable when in neutral.
That and the power steering pump are my March projects and I'm actually looking forward to both!
Old 03-12-13, 07:48 AM
silos5
silos5's Avatar
tran mount is super easy to change.
mine was split in 2 pieces when I replaced it...no wonder vibration can come from it.
Old 03-12-13, 08:42 AM
Eds98LS
Eds98LS's Avatar
Shoot, I'm sure mine is in similar shape then!
Old 03-12-13, 08:55 AM
rome99LS
rome99LS's Avatar
Yea I had that issue a year ago. Change it and u will notice a difference right away....its cheap and easy to change. Did mine in 15mins.
Old 03-12-13, 11:49 AM
Eds98LS
Eds98LS's Avatar
Just wondering, did you all replace the trans mount with the car entirely off the ground or can the part be removed with just the front two wheels jacked up? I know I'll need to support the transmission in order to remove and replace the old piece.
TIA
Old 03-12-13, 03:50 PM
YoshiMan
YoshiMan's Avatar
You just need to make room under the car and be able to support the tranny with a jack when you unbolt the crossmember. If you were REALLY skinny you could just do it with all four wheels on the ground!
I just did mine last week, it was still intact, but had collapsed to less than half the height of the new mount. fixed the driveline vibes too
Old 03-12-13, 04:05 PM
Eds98LS
Eds98LS's Avatar
Haha. I'll jack the front up then real high. Glad I don't have to take the whole car in the air.
Really looking forward to this fix. Been driving me nuts for months!
Old 03-13-13, 04:51 AM
rome99LS
rome99LS's Avatar
I did minw on the Alignment Rack at my job. And no wheels was in the air. So I agree with yoshi.
greens14
Performance & Maintenance
06-17-13 02:02 PM
Eds98LS
03-30-13 08:27 PM
2jzgttegs
02-18-13 06:36 AM
djl
Suspension and Brakes
08-09-04 12:27 PM
Quick Reply: Transmission mount issue
