Car Completely Dead
Car Completely Dead
I went to go park my car but realized that It was too far away and as soon as I try and start the car everything is dead. None of the lights in the car work, I can't lock the car or anything. It shouldn't be the alternator right because i'll still have some kind of power if it was? My LS is a 99 if anyone can help me.
The terminal posts and cable ends didn't even look all that bad but cleaning them with a cheap tool from Autozone to make them bright and shiney did the trick. And yes, be sure to tighten the cable connections very tightly ... and then coat them and the battery terminals with something like Vasoline to inhibit corrosion.
That battery that I almost discarded has been working great all winter including days where the car has sat unused outside all day in 10 to 15 degree temperatures.
Super Moderator
Good practice to remove the battery cables and clean them periodically to make sure the contact surfaces are clean. One time I'd parked the car then when returning a few hours later it wouldn't start. Removing the positive battery cable cover revealed lots of deposits on the terminal.
every LS400 owner needs to be aware of that connection where the last two inches of the + battery cable (the terminal end itself - which is a separate part from Lexus) connects to the main cable by way of a bolted connection that can become riddled with hidden corrosion that can confound its owner, as the actual connection at the battery posts can be completely clean and yet you have no start even with a new battery and alternator!
I replaced mine which was 16 years old - p/n 90982-05037
kyvak
08-04-17 11:34 PM
