upper ball joint
Old 12-14-02, 09:27 PM
humza107
humza107's Avatar
Question upper ball joint
Hi everyone, I have a 92LS400, my upper passenger ball joint needs replaced. Where is the best place to get it? And also, can I get one w/o having to replace the whole control arm. Also,, where can i get a A/C pump, mine is shot. Thanks
Old 12-15-02, 04:35 PM
Maeve
Maeve's Avatar
Default Re: upper ball joint
call these places first http://yp.yahoo.com/py/ypResults.py?...75.163773&cs=4
goodluck
Old 12-16-02, 03:47 AM
humza107
humza107's Avatar
thanx, but should i ask for a whole arm, or just the ball joint, i heard the the ball joints aren't pressed? What should I ask for?
Old 12-24-02, 03:09 PM
Rice
Rice's Avatar
I was trying to replace bushings in my spindles(rear) w/o replacing the spindles. It was a waste of time, so I eventually had to buy the whole assembly.
My advise is go to the dealer and buy the upper control arm.
It's about $300 there. In addition to new ball joint, you will get 2 new bushings that also ware out and cause noise. Yours' are probably worn, judging by the fact that the boll joint went.
Good luck.
Old 12-25-02, 10:30 PM
Maeve
Maeve's Avatar
the diagram helps a lot, Thanks
ahero4all
Suspension and Brakes
02-28-18 12:31 PM
ACLC
Suspension
08-23-14 09:20 PM
frankjames
07-20-09 09:51 AM
92blacktt
05-17-09 05:32 PM
en11871
01-30-08 01:52 PM
Quick Reply: upper ball joint
