please post up any LS400 OEM's if you know them
I'll start:
struts - KYB
shocks - KYB
oxygen sensors - NipponDenso
water pump - Aisin
radiator hoses, rubber fuel hose, most other hoses - Toyoda Gosei
air filter - Toyota Boshoku, NipponDenso
oil filter - Toyota Boshoku, NipponDenso
cabin air filter - Toyota Boshoku
TPS - NipponDenso, Aisin
ECU - NipponDenso
Crankshaft position sensor - NipponDenso
Camshaft position sensor - NipponDenso
Engine Coolant Temperature Sensor - Ohizumi (NTC), Semitec
thermostat - Kuzeh
timing belt - Bando, Mitsuboshi
serpentine belt - Bando, Mitsuboshi
ABS modulator - NipponDenso
windshield - Asahi Glass
Idle Air Control Valve (IACV) - NipponDenso
Idle Air Control Valve bearings - NSK
stereo - Pioneer, Nakamichi
spark plugs - NipponDenso, NGK
spark plug wires - NipponDenso, Sumitomo
most interior parts such as seats, trim, headliner - Toyota Boshoku
weatherstrip, door/window/trunk seals - Toyoda Gosei
alternator - NipponDenso
idler bearing - Koyo, NSK
timing belt tensioner bearing - Koyo, NSK
timing belt hydraulic tensioner - NTN
fan clutch - Aisin
A/C compressor - NipponDenso
A/C pressure switch - NipponDenso
engine oil - Mobil (but to a unique Toyota specification that exceeds Mobil's other synthetics)
oil pump - Aisin
transmission - Aisin
transmission fluid - Mobil (3309)
wheel bearings - Koyo
distributor caps & rotors - NipponDenso
brake calipers - Akebono, Aisin, Sumitomo
brake pads - Akebono, ATE, Sumitomo
brake rotors - Kiriu, ATE
starter - NipponDenso
headlights - Koito
brake lights - Koito
turn signal lens assemblies - Koito
strut bars (caster arm) - Toyotetsu (Toyoda Iron Works)
tie rod ends - Toyotetsu (Toyoda Iron Works)
upper control arms - Toyotetsu (Toyoda Iron Works)
door lock actuator motor - Mabuchi
airbag sensor - Nippon Denso
The following 4 users liked this post by LScowboyLS:
I would love to know the OEM for inner & outer tie rod ends, strut rods, upper control arms, bushings, and other suspension components, if anyone can contribute on that.
Awesome thread is awesome, however, isn't the trans fluid strictly Toyota T-IV whereas the power steering fluid would be Mobil? Just wondering.
We need an aftermarket section thread, I might sort all these into categories in my spare time. This is great info.
and if your Mazda dealer has a better price, you can certainly buy your Mobil 3309 from them:
advics also makes oem toyota pads..
I've been underneath my car for the last half hour or so, and the back of my calipers are marked "Sumitomo." I see you stated Akebono as the OEM supplier and Sumitomo as a possible pad supplier, but would it be possible for Sumitomo to have made the calipers as well? Mine's a '97.
however, many LS400 calipers 97 and earlier were Aisin
BahHumBug
the problem i see here is that toyota has used different manufacturers for the same part in the SAME YEAR, and uses different manufacturers for the same part across different years. so this would only be useful if you say what years that manufacturer made said part.
'95-00 afik:
Air filter:NipponDenso
Front brake calipers: Sumitomo
more when i have time and rest
'95-00 afik:
speaking of Sumitomo, I understand that they are no longer in the caliper business, and that Advics has bought up all of their plants and tooling etc.
Toyota doesn't manufacture any fluids, they buy them from the petroleum refiners, Toyota T-IV is just relabeled Mobil 3309 ATF that is just sold in a Toyota bottle. It's Aisin who specifies this fluid.
i would assume toyota actually makes the tie rods, and suspension components besides the struts themselves.
Most of engine temp sensors used for Toyota are supplied from 2 major companies, SEMITEC and OHIZUMI. P/N 89422-20010 must be manufactured by one of them.
Yes, KUZEH is supplying thermostats to Toyota. I found mine was KUZEH
As far as I know, tie rod ends and upper control arms are manufactured by TOYOTETSU
どうもありがとう muchas gracias!!
