1999 Lexus Code P0430
Old 11-09-12, 12:09 PM
flyboyplo
flyboyplo's Avatar
Default 1999 Lexus Code P0430
I had previously fixed my P0420 which was the passenger side, now the driver side went on ... It was costly to fix 500 was the best deal for original cat ... now the check engine light had went away but the car is running rich and it idles when its cold at 1.5-2.00 .... any suggestion of what should I do ? no leaks that I can hear ... it was a leak at the gaskit but I fixed it then this code went on ... what should I do? plz help
Old 11-09-12, 07:25 PM
RA40
Super Moderator
RA40's Avatar
Welcome to Club Lexus. The FAQ section is for additions or suggestions for the FAQ. Trouble shooting posts should be posted in the main forum section. Thanks.
Old 11-10-12, 11:04 AM
RA40
Super Moderator
RA40's Avatar
What kind of MPG is it getting now? You already did the gasket , go back and verify the sealing. A leak at the midpipe will still change the value the O2 sensor can read.
If good, replace the top bank O2 sensors (may as well do the second bank sensors since you are under the car and to be sure IMO), clear codes by removing the neg battery cable for about 30 seconds. Drive car and see if the P0430 returns, if it does then you know the cat will need attention.
STREETGS
12-26-19 02:34 PM
vighnesh
Hybrid Technology
05-07-19 02:03 PM
massakill
Performance & Maintenance
11-03-18 08:06 PM
tonycard
11-18-14 09:36 PM
pslack
Maintenance
02-01-13 02:42 PM
Quick Reply: 1999 Lexus Code P0430
