air to coil questions
Old 10-14-12, 10:27 AM
g3t0ut
g3t0ut's Avatar
Default air to coil questions
I have searched but i couldnt find anywhere what i will be needing to swap over the air suspension on a 95 to coilovers. i just picked up the 95 with bad air suspension. Do i need any additional parts or does it just bolt right up.
thanks
Old 10-14-12, 10:58 AM
SpencerT
SpencerT's Avatar
Lextreme has a tutorial for the first gen. It should be good enough to get it done.
For some reason I ant access the lextreme website right now though...
Old 10-14-12, 01:07 PM
g3t0ut
g3t0ut's Avatar
That was another reason I asked..I couldn't get on the site either
Old 10-14-12, 04:50 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
the site will be back up soon, lextreme is aware.Same as standard shock changeover just remember to pull the air suspension fuse from the fusebox after.
Old 10-18-12, 01:04 PM
g3t0ut
g3t0ut's Avatar
do you happen to know the name of the fuse. i cant find one that i believe to be related to air suspension
ReeM
Suspension and Brakes
11-22-16 07:10 PM
jasone36
10-03-15 09:56 AM
njumongkol
Suspension
01-16-10 01:35 PM
B.Diddy
20
04-23-09 12:06 PM
Quick Reply: air to coil questions
