What did you do to your LS400 today?
Old 12-20-15, 06:18 AM
  #331
JJDAG
JJDAG's Avatar
Originally Posted by RA40
Did this to ours a few days back:
This is driven about 6K annually so to hit 300K miles it will take 17 years.
My LS just turned over to the 100k mark the beginning of the month. 12k in 7 months
Old 12-20-15, 07:40 AM
  #332
pmarr
pmarr's Avatar
This is what my daughter brought me this morning. Goodbye perfect LS....
Old 12-20-15, 10:32 AM
  #333
RA40
Super Moderator
RA40's Avatar
Ouch. Good that it came back and she's ok.
Old 12-20-15, 09:15 PM
  #334
YODAONE
YODAONE's Avatar
Installed thermal and sound barrier covers on fuel injectors;
https://www.clublexus.com/forums/ls-1st-and-2nd-gen-1990-2000/806637-fuel-injector-covers.html
Old 12-20-15, 09:18 PM
  #335
YODAONE
YODAONE's Avatar
Installed thermal and sound barrier covers to fuel injectors
http:// https://www.clublexus.com/fo...or-covers.html
Old 07-02-16, 03:07 PM
  #336
RA40
Super Moderator
RA40's Avatar
Replaced the 205K mile PCV valve, grommet and hose. The rubber parts were brittle and pretty much crumbled. I cut the grommet across the top then made another incision down the hole. It slipped into the vale cover while trying to pull it up but because of the baffle it was easily retrieved. If not for the cut splitting it, getting that round thing out would have been more challenging.
Checked the throttle body but it was pretty decent. Not much different than it was at 70K miles so it was left as is. Torqued the valve covers since they have been leaking. Discovered an oil leak down around the oil filter but since I was topside I couldn't see where that was originating.
This week an oil and tranny fluid drain then I'll look to see where the oil leak is coming from.
Picked up a 3/8 CDI 752MFRMH torque wrench so I was in playing with it, also have the 1/4 version and like that one too.
Old 07-03-16, 11:58 PM
  #337
96UCF20
96UCF20's Avatar
208,000 glorious miles have led to this moment, haha!
Old 07-04-16, 05:01 PM
  #338
Hayce
Hayce's Avatar
Changed the valve cover gaskets. What a mission that was. Well that was a few weeks ago but today I finally figured out why I had check engine/VSC after it. "Reset VSC".. wow.
Old 07-06-16, 10:56 AM
  #339
Legender
Legender's Avatar
96UCF20,
I don't remember when was the last time, or first time I saw a butterfly that encrusted...
Your gas mileage should improve just by removing the weight of all that crud.
I'd say you were over due
Old 07-06-16, 03:53 PM
  #340
96UCF20
96UCF20's Avatar
Originally Posted by Legender
96UCF20,
I'd say I was overdue as well! I got a P0172 code which led me to clean my MAF sensor as well my throttle body. I was expecting the throttle body to be dirty but not to that extent! We cleared the CEL after cleaning both the MAF sensor and throttle body and the CEL has not returned. The vehicle's throttle response has greatly improved and is much smoother now!
Old 07-11-16, 08:11 PM
  #341
JradCelly
JradCelly's Avatar
Today I got around to installing my RCR taillights.
I actually drove 6 hours from Vancouver BC to Kent Washington to get these . Everywhere I looked online was out of stock apparently DEPO stopped manufacturing them as far as I know.
I think they look pretty good !
Old 07-11-16, 09:09 PM
  #342
djamps
djamps's Avatar
Changed the diff fluid. Took all of 30 minutes lol. I slacked on doing it a while back when I did the trans due to not having a 10MM hex socket and a oil pump. Looks like diff bushings are not far down the road.
Old 07-11-16, 09:13 PM
  #343
djamps
djamps's Avatar
Is this because of the EGR? I'd hate to see what the rest of the manifold looks like. My 98 has almost nothing on it after 200k.
Old 07-11-16, 11:38 PM
  #344
96UCF20
96UCF20's Avatar
I'm not too sure to be quite honest. I purchased the car roughly two months ago and I've been slowly going through the whole car and tending to all the negligence. The intake manifold received some attention as well but it was nowhere near as bad as the throttle body.
Old 07-12-16, 09:23 AM
  #345
Legender
Legender's Avatar
Could have simply been the quality of gas used in combination with a lack of cleaning. Recent AAA report shows that non top-tier gas is worse for cars...or something like that. I remember the 19x just not the other part.
Quick Reply: What did you do to your LS400 today?
