What did you do to your LS400 today?
Old 11-15-15, 05:30 AM
  #316
billydpowe
billydpowe's Avatar
well, I just drove by Park Place Lexus and got a complementary car wash......
Old 11-16-15, 12:33 AM
  #317
dicer
dicer's Avatar
https://www.clublexus.com/forums/is-...-car-wash.html
Is there any paint left?
Old 11-16-15, 04:01 AM
  #318
Bprakash
Bprakash's Avatar
I restored the engine and suspension. Drives new again.
Old 11-23-15, 09:18 AM
  #319
Hiroshi12
Hiroshi12's Avatar
Any details?
Old 11-23-15, 05:40 PM
  #320
AandSC
AandSC's Avatar
Just finished up:
Timing belt
Water pump
Timing belt tensioner and pulleys
Drive belt
Thermostat
Spark plugs
Coolant flush
Upper and lower radiator hoses
Oil and filter
Air filter
Transmission drain
Cleaned throttle body
Wax job
Car runs very smoothly now and looks almost as good as new. Started Friday after work and probably spent about 16 hours over the four days. Could do a timing belt change much quicker now that I know what I'm doing. Having a lift and a nice set of tools helped immensely.
Old 11-23-15, 07:30 PM
  #321
scunyon
scunyon's Avatar
Finally got around to doing the JBrady intake mod. Now I'm shopping around to get the rear 2 resonators deleted.
Going to do some under the hood detailing tomorrow.
Brake caliper paint will hopefully be done before Thanksgiving is over.
Old 11-26-15, 09:10 AM
  #322
JZRyan
JZRyan's Avatar
After being without a Lexus for over a year I caught myself checking around Craigslist and found a '96 LS400 for 1500. I decided to check it out... The engine was running on 5 or 6 cylinders, clear coat peeling at tops of doors and hood, leather seats cracked, chrome peeling from wheels, headlight bracket broken, grille cracked... Still a solid car though haha. I offered 700 and got it for 900. Today I put plugs and wires in and she runs like a top. Also put 350z wheels on until I can get something else. Really excited to have an LS again, this is my first 95+
Old 11-26-15, 04:47 PM
  #323
Bprakash
Bprakash's Avatar
I spent 7K. All new parts for the suspension...every bushing, every arm, every shock and mount, new Rack, all new ignition parts, every filter, all fluids, full TB, water pump, thermostat, every belt. Drives new.
Next I will replace the leather seat covers, dye the steering wheel and shifter. Has 188K. Want to drive it to 400k mls. Nicest car I have owed. Better than my 2010 SC 430.
Old 11-27-15, 12:32 AM
  #324
dicer
dicer's Avatar
What year car? 7K ? wow, who did the work? So whats next a $4000 engine rebuild and a $3000 transmission rebuild, and don't forget the rear end, another $1000 or maybe some what less. Hows the paint an body and inside?
Old 11-27-15, 02:48 PM
  #325
scunyon
scunyon's Avatar
Default A little more paint work
Playing with the brakes today... I've got some overspray and touch up to do, but I'm pleased with how it looks.
Old 11-27-15, 04:20 PM
  #326
AandSC
AandSC's Avatar
Great job on the brakes! Which paint did you use and where did you get the decals?
Old 11-27-15, 04:26 PM
  #327
scunyon
scunyon's Avatar
Thanks! I used VHT engine enamel. I put the primer on first, then the white and decals, followed by the clearcoat.
I got the decals from m3kgtguy on eBay. Got the decals in about 4 days from AZ to SC. Less than 10 bucks for high temp vinyl. He does custom colors as well but they take a little longer and add to the cost a bit.
Old 11-27-15, 06:19 PM
  #328
dicer
dicer's Avatar
I like it way better than rust. But for anyone else or next time maybe remove them and don't paint the hose or wire, it would look real professional.
Old 11-27-15, 06:22 PM
  #329
scunyon
scunyon's Avatar
Yeah. I'm gonna upgrade to stainless steel lines when I swap the rotors.
Old 12-18-15, 05:15 PM
  #330
RA40
Super Moderator
RA40's Avatar
Did this to ours a few days back:
This is driven about 6K annually so to hit 300K miles it will take 17 years.
Attached Thumbnails What did you do to your LS400 today?-200k-lex-december-15-2015-7440.jpg
Quick Reply: What did you do to your LS400 today?
