All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
Old 02-24-14, 06:08 PM
  #721
joelpr1234
joelpr1234's Avatar
Originally Posted by LScowboyLS
could you post all of the information on the various caps that are in these pics?
ECU: 37820-P06-A50
Caps:
3- 33uf 35v
1- 47uf 10v
1- 100uf 10v
1- 220uf 10v
1- 220uf 35v (I got an ecu with this one burned, I was reading that is recommended to replace it in many honda forums)
I got them using the links in the op and searching in digikey
Old 03-03-14, 07:51 AM
  #722
metalman
metalman's Avatar
I went with some suggestion here and bought a second ECU off ebay.........It pays to wait, when you get one for $45 free shipping. Came from Canada, so maybe the Caps aren't so fried. Runs good for now, will send the original out for service when I get a chance. My charging issue was Power steering fluid in my new alternator. It was a major leak, filled every 2 days. Fixed by plugging hole with bolt for now. (if I could only buy the O rings for the sensor.) No problems after cleaning it. I love this car more everyday.
Old 03-03-14, 11:08 AM
  #723
dveneman
dveneman's Avatar
Sounds like you got lucky with the alternator.
"..will send the original out for service.........." Waiting for it.
Old 03-06-14, 12:30 AM
  #724
Roel2377
Roel2377's Avatar
Who do you recommend to fix my 98 sc 400 ECU I need it to be fix ASAP!
Old 03-07-14, 02:58 PM
  #725
Shiftone
Shiftone's Avatar
Hi all, New to the forum and new Lexus owner. I was given a 92 SC300 with no ECU and apparently major issues. I am currently buying a ebay ECU as I have not been able to locate an ECU matching the part # the Dealer gave me based on the VIN#.
In my search I came across this thread and believe I will change the caps when I receive the ECU. Does anyone know which caps I need and how many of each?
I would like to order them and get them when the ECU gets here. ECU# 89661-24312
By the way this thread is dripping with genius!
Old 03-07-14, 05:05 PM
  #726
LScowboyLS
LScowboyLS's Avatar
It would be prudent to order the caps after you have received the ECU and verified which ones it contains, but they should all be linked to in my list in post #1 - make sure you order the exact caps linked to, there are no substitutes that will work. - In other words, just getting the cap's size and voltage correct is not enough, these caps are a particular very rare type, they are not available locally, they are almost not available outside of Japan!
and get some verification of that ECU number, such as some buddies with the exact year model of SC300 over in the SC section of Club Lexus or in your town.
Old 03-07-14, 06:01 PM
  #727
Shiftone
Shiftone's Avatar
Will do on the caps and good idea on askin the guys in the sc forum. Thanks for the suggestions.
Old 03-08-14, 07:05 PM
  #728
sshhlexus
sshhlexus's Avatar
Any recommendations for a good 40W+ soldering iron?
Out of 3 soldering irons, or 2 now in my toolbox.
1. The good quality one I have is only 25W and I have 2 clean tips for it.
2. This one is an old black radio shack 35W, no tips, just one very dirty tip.
3. The 45W one is in the wastebasket. It smokes when you plug it.
In examining the boards, the original and a spare, it really takes a toll on my eyesight. I've been using a light and magnifying glass. Any ideas on how to better view the board up close.
Thanks in advance.
Old 03-08-14, 07:19 PM
  #729
LScowboyLS
LScowboyLS's Avatar
the one I mentioned in post #1 of this thread is a good one and it is dirt cheap at radio shack
the part number is in post #1 of this thread in the recommended tools section!
Old 03-08-14, 07:20 PM
  #730
LScowboyLS
LScowboyLS's Avatar
I use an LED headlamp and clear Dewalt safety glasses
Old 03-09-14, 07:20 PM
  #731
petebrown
petebrown's Avatar
Hi - i'm able to get the ECU capacitors replaced by my local electronics shop ... however they don't have the exact capacitors you mention.
Here is there reply ... can you let me know if this would be ok or do i really need to source the low ESR types instead.
thx
pete
Me:
what about the capacitors themselves ? The forum link I sent you was very specific about the type and quality of capacitor that needed to be used – do you have those type in stock or do I need to source them ?
Electronics shop reply:
We do have these capacitors in stock except for the 15uf which can be replaced with a 22uf, should have no effect on the device just higher amount of storage and filtration. We do not carry the low esr capacitors as they suggest as from experience we found the low esr caps did not last as long as the TKR capacitors we use. If you would like to source the exact ones for your peace of mind that is fine, Our supplier does not have the 15uf capacitors specified. If you would like us to fit our parts you are welcome to bring the computer in at any time between 9am-5pm Mon to Fri. Just give us some time with it at worst 1 day.
Old 03-09-14, 07:31 PM
  #732
LScowboyLS
LScowboyLS's Avatar
NO!, that is completely incorrect and I would not end up using this shop for this reason!
Low-ESR, high ripple rejection capacitors are mandatory! - this shop is not a Nippon Denso engineer, it is some goofballs! - our resident ECU engineer from Japan, Yamae-san, has talked about this at length in this thread - he has over 100 patents and is pretty famous in the electrical engineering world, please listen to him!
and I say your shop does not have ANY of the precise capacitors I listed in stock, they are not even available in Australia! - they are just barely available outside of Japan!
Old 03-09-14, 07:57 PM
  #733
petebrown
petebrown's Avatar
Hi - thx for the quick reply.
I've now ordered the exact capacitors you have advised - should be here within 4-5 days.
I'm happy to use the shop - i've found them to be very straightforward and honest in my dealings with them and i'm confident in their ability to replace the capacitors.
I'll post back to the forum once i have the capacitors replaced and let you know if it's fixed my problems.
For the record they are:
- Dash flickers off for 30 mins after about 5 mins of driving and then comes back on for the duration of the trip - been like this for about 12 mths now.
- Just last week the car started playing up when i try and accelerate quickly - it just misses and sort of "shunts" - if i very progressively step on the accelerator it reaches 100kmh and cruises.
I'm also going to check the codes as described here - http://www.lexls.com/tutorials/intro/codereading.html - as i have had the central air-conditioning vents producing no air for the last 6 years.
thx
Pete
Old 03-09-14, 08:40 PM
  #734
LScowboyLS
LScowboyLS's Avatar
well I am thinking you may have multiple issues, not just ECU capacitors
the dash flickering is likely the capacitors in your instrument cluster circuit board
the A/C vents are likely a different problem, as the ECU primarily only controls the compressor itself, the no air could be a blend door, a cable, a vacuum leak or the control board or even the blower motor - does the car blow heat or even room temperature air?
if the air is just not COLD, then *that* can be ECU caps
this "miss" or "shunt" could definitely be ECU caps, especially if the car is in the 92-97 range, as that is where the epidemic is! - although other years of Lexus and Toyota also have caps go out in the ECU, just not as commonly as 92-97
Old 03-09-14, 09:29 PM
  #735
petebrown
petebrown's Avatar
AC blows beautiful cold air through the side vents - works well enough to cool the interior no problem on a hot day (that's why i've never worried about it) - just doesn't work through the front centre vents nor the rear vents. Will the codes i'm going to check as per - http://www.lexls.com/tutorials/intro/codereading.html - help locate the problem ?
As for the dash - it doesn't actually flicker as such, when it's on it's fine - it just goes off for 30 mins and then comes back on (but perhaps that's what you meant anyway).
Is there info available on the capacitors required for the instrument cluster circuit board - i might do that after this if the dash problem still exists.
BTW ... thx for all your information - it's a wonderful thing you do.
cheers
Quick Reply: All my crazy Lexus issues SOLVED!! (ECU-leaking capacitor)
