brake bleeding
brake bleeding
I've read LexLS.com guide on how to bleed the brakes on our LS. The fluid in the reservoir looks kinda brownish.
It was never mentioned if the ngine should be running or not while bleeding the brakes. I apologize if this is a dumb question but I've never flushed a brake system before.
Whats the correct procedure? Engine on or off?
How many quarts of brake fluid do I need to completely flush out the old fluid -- 1999 LS400.
thanks.
thanks.
i want to get ride of all the old fluids to,is it possible to just open 1 valve and then pump brakes to get ride of the older fluids while adding new fuilds when the older fluid gets low so it wont add air into the system?? them do individual wheel??
Super Moderator
Suck the old fluid out of the reservoir. Depending how old it is, there can be some nasty particulates floating in there. You'll want to get that out so it isn't pushed through the ABS. You won't get the stuff in the forward chamber out but back two are prone to more to oxidation and contamination since these are closer to the fill cap.
To me it makes more sense to have the motor running so the boost is avialable for better flow.
Can anybody pls tell me the amount of fluid I need to have in order to get this job done? thx.
