Turning off OEM Air Suspension in an LS400/Celsior
Hi Guys,
I've just put coil overs in my UCF11 Celsior, I've just removed tge factory air struts and replaced them with the coil overs, what are peoples recommendations fro what to do with the rest of the setup? Compressor, lines, ecu stuff etc....
Can it be easily taken out? I have it switch OFF at the moment (the boot switch) but the Height light on the dash is blinking which pisses me off, anything I can do to make that not happen? Like unplug something or whatever?
Cheers
Cheers
I don't have the air suspension but I believe others commented on how they pulled the fuse for the compressor. I do not know if there is a fuse to disable the suspension ECU.
Check this out:
https://www.clublexus.com/forums/3399972-post10.html
Check this out:
Ceriel
20
11-05-16 07:13 PM
