Electrical problem 95 ls400
Old 08-13-12, 08:09 AM
Diazg07
Diazg07's Avatar
Default Electrical problem 95 ls400
I tried to delete this post but it not letting me sorry guys
Last edited by Diazg07; 08-15-12 at 04:56 AM. Reason: Forgot to put some information
Old 08-13-12, 01:28 PM
RA40
Super Moderator
RA40's Avatar
What is the issue you car is having with the electrical system?
Old 08-13-12, 02:16 PM
timmy0tool
timmy0tool's Avatar
still sounds like a bad alternator. how did you know your alternator is good? how was it checked?
Old 08-14-12, 02:55 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
check the fusible link from the alternator, if it's been tripped it would need to be replaced before the alternator will charge the battery again.
please do not create multiple threads on the same topic.
Old 08-14-12, 08:27 PM
PureDrifter
BahHumBug
if it's reading 19v your "new" alternator has a dead voltage regulator...
Old 08-15-12, 05:07 AM
Diazg07
Diazg07's Avatar
Default Electrical leak
I was trying to find a short so I did the test with the little bulb and I pulled all the fuses I could find(engine compartment and under the steering wheel) but the bulb still stayed on so I had no luck trying to find the short. I disconnected my positive cable and put the little clamp on the battery post and put the sharp pointy end on the positive cable, at least I think I was doing it right. Any ideas on what to do next or where to look?
JoZ89LS40
03-29-19 06:39 PM
flcamacho
ES - 5th Gen (2007-2012)
03-25-17 11:28 PM
rakett
GS - 1st Gen (1993-1997)
08-21-14 04:05 AM
lextout
16
09-30-12 02:02 PM
Quick Reply: Electrical problem 95 ls400
