which components could cause this weird behavior?
Old 07-22-12, 10:34 PM
LScowboyLS
LScowboyLS's Avatar
Default which components could cause this weird behavior?
my '96 LS400 will be running fine, then suddenly the following things will happen simultaneously, but with no codes set in ECM:
green PWR transmission mode dash light goes off
check engine light comes on
transmission no longer will shift automatically, must be manually shifted in order to drive
A/C stops working
Front defog red light flashes approx. ~10 times
speedometer not working, remains at 0
engine runs poorly
bad smell from exhaust
then seconds or minutes later, the check engine light goes off, PWR light comes on, and everything above is now working perfectly!
I am thinking that very few things could cause all of this at once, my candidates I have thought up are: ECM, TPS, crankshaft position sensor, or perhaps main engine relay or EFI relay --- any other components that might be the culprit?
and there is no pattern to it, no time pattern, no engine or ambient temp pattern, as random as a loose connection and NO codes set in ECM
anyone recognize these symptoms?
Old 07-23-12, 01:47 PM
LScowboyLS
LScowboyLS's Avatar
Guys, seriously
I need help! - someone has seen this before.
what does the flashing front defog light mean, is it a code?
how many things on the car could make the transmission not shift, A/C not work, and speedometer not work, then suddenly go back to everything working fine with no codes set?
Old 07-23-12, 02:19 PM
McPierson
McPierson's Avatar
Bad ground?
Old 07-23-12, 08:02 PM
cobalt91
cobalt91's Avatar
Trunck harness possibly.
Old 07-23-12, 09:36 PM
Lavrishevo
Lavrishevo's Avatar
+1 Check the harness at your trunk near the hinges for breakage or shorting. If that is not the case then I would look at the ECU itself. Some of your symptoms are similar to when the ECU is reset, such as the defrost flashing and no A/C till it goes through its self-check mode.
Old 07-23-12, 10:50 PM
mspearl95
mspearl95's Avatar
Originally Posted by McPierson
Bad ground?
this is what i was thinking too, some kind of disruption in battery connectivity/power supply. The defrost light will flash when the climate control system is powering up for the first time, like after you've had the climate control unit unplugged. Thats also why your A/C would stop, as the CCU is setting itself. Check the big ground strap that bolts on near the ac compressor. Mine was WAY loose when i got my car. The bolt was almost backed all the way out..
Also, I may be wrong, but I thought the trunk harness problem was only in gen1 LS?
Old 07-24-12, 12:14 AM
LScowboyLS
LScowboyLS's Avatar
the thing is, it is more than a reset, it can stay in this screwed up mode for days or just seconds, even blink back and forth from perfect to screwed up, no pattern!
I will check the grounds mentioned
where are other grounds located that have also been at issue on LS400's?
Old 07-24-12, 04:22 AM
Yamae
Yamae's Avatar
It seems to me that the ECU enters the safe mode. When the DC for the main processors is not stable, the ECU enters the safe mode. Have you ever checked cold solder joints or cracked solder points for the DC regulator circuit in the ECU unit?
Tapping the ECU can sometimes duplicate the problem easily. I suggest you to monitor the voltage for the Vcc line which is the output of the DC regulator while tapping.
Old 07-24-12, 07:43 AM
LScowboyLS
LScowboyLS's Avatar
Wow - great info!!
this is what Club Lexus is all about!!!
Old 07-24-12, 10:47 AM
GS4_Fiend
GS4_Fiend's Avatar
Whats the code?
Old 07-24-12, 12:04 PM
RA40
Super Moderator
RA40's Avatar
Trunk harness is typically with the 1-LS. There have been posts about ECU issues on 95 and 96. I would initially suspect a grounding issue. Check the battery cables and trace back through the harness for any signs of damage, etc. Like critters making a meal of the wiring looms.
Old 07-24-12, 10:42 PM
LScowboyLS
LScowboyLS's Avatar
could someone direct me to the location of the most critical ground straps on the car, for this kind of issue?
the only one that has been mentioned here is the one near the A/C compressor
I have the factory service manual, but it is rather quiet about the location of the most critical ground points
Ladoo1980
IS - 1st Gen (2001-2005)
04-23-17 10:28 AM
Southaven
Performance & Maintenance
07-08-16 07:52 AM
rob328
06-04-11 09:07 PM
1994 LS400
08-11-02 08:40 PM
Quick Reply: which components could cause this weird behavior?
