seafoam 95 ls400
Old 07-05-12, 09:33 AM
Xaolin
Xaolin's Avatar
Default seafoam 95 ls400
i have a 95 ls400 i seafoamed it and now my oil light is on. i hooked up my computer up to it and nothing isn't showing. did it mess up my sensor or my oil pump. any help will do.
Old 07-05-12, 09:50 AM
mspearl95
mspearl95's Avatar
I can't say for sure either way, but it seems like it would be the sensor. Seafoam doesn't get into the crankcase does it? Purely a fuel/emissions treatment? have you checked to see if you knocked the wire loose on the sensor when doing the treatment?
Old 07-05-12, 12:00 PM
RA010623
RA010623's Avatar
did you check your oil level?
Old 07-05-12, 12:46 PM
Xaolin
Xaolin's Avatar
i was no where near the sensor wire. and yes the oil level is on the dot.
Old 07-05-12, 02:03 PM
RA010623
RA010623's Avatar
checking the sender wiring also try to change the oil. you should change oil / spark plug after you run seafoam.
Old 07-05-12, 02:15 PM
Lavrishevo
Lavrishevo's Avatar
+ 1 on the plugs.
Old 07-06-12, 02:22 PM
cobalt91
cobalt91's Avatar
Are you saying the seafoam treatment fouled or ruined the plugs?
Old 07-06-12, 08:52 PM
Lavrishevo
Lavrishevo's Avatar
It is highly recommended that you change the plugs after the Seafoam treatment. You are cleaning all that carbon out of your intake and it can easily foul up the plugs. If you still have new plugs then inspect and clean.
Old 09-05-12, 12:25 AM
hotdawwg
hotdawwg's Avatar
Isn't sea foam really bad for your car!?
Old 09-05-12, 01:09 AM
PureDrifter
BahHumBug
PureDrifter's Avatar
no, search.
Old 09-05-12, 04:55 AM
lextout
lextout's Avatar
Another reason why i don't use the after market additives, even if the dealer sells them they get commission from the additive company them selves.
Old 09-05-12, 07:59 AM
hotdawwg
hotdawwg's Avatar
Originally Posted by PureDrifter
no, search.
Well we don't use use it on our G35/G37's due to horror stories of sensors going crazy and horrible idles after, I have just noticed that its talked about quite frequently here on CL.... Sorry, I also have a G35 that I have had for 5 years...,
Old 09-05-12, 12:15 PM
RA40
Super Moderator
RA40's Avatar
Here and there we'll read of problems following. Variety of reasons exist though with a healthy engine, the recommended use -should- be fine. Remember "stuff" happens so it it is a risk. That old saying, "don't fix what isn't broken."
Old 09-05-12, 03:11 PM
LS400BOY
LS400BOY's Avatar
I added sea foam to my crancase for 2-3 weeks then got a oil change, nothing happend bad as far as spark plugs
Old 09-05-12, 04:41 PM
PureDrifter
BahHumBug
wow you generally don't wanna ever do that. Seafoam really shouldnt be run in your oil for much longer than it takes the car to get to operating temp and then maybe another 10 minutes.
Seafoam in oil has next to no impact on spark plugs anyways, that's only an issue when you run it through the intake tract.
Quick Reply: seafoam 95 ls400
