Sunroof help
Old 07-05-12, 09:02 AM
dtLS400
dtLS400's Avatar
Default Sunroof help
Hello CL, I have a 92 ls400 with 241,xxx on the clock. Recentlyy sunroof has not been operating properly. I can not roll the sunroof back or tilt it closed... It will tilt open bit will not tilt to close . Luckily it's summer and I'm in California no rain please for I have my sunroof left at the tilt open position. Sometimes it will work to tilt close but will not close all the way because the widow open chime
Will sound when I remove the key from the ignition.
Thanks in advance
Old 07-05-12, 10:26 AM
vicsis250
vicsis250's Avatar
Try maybe spraying some oil or WD-40 sometime that will loosen up what ever is in their
Old 07-05-12, 05:02 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
check the rails and make sure nothing's stuck in there.
Old 07-05-12, 06:48 PM
dtLS400
dtLS400's Avatar
Thanks or the replies , I got it to close after tilting it up all the way and tilting it down completely. It might be that the rails need re greasing.
skins990
06-27-17 08:26 PM
Gabrielc
06-18-17 03:46 PM
SeanO
04-12-14 09:40 PM
pk3
RX - 1st Gen (1999-2003)
04-09-13 12:46 PM
Quick Reply: Sunroof help
