finally found Stainless Steel Brake Line for UFC20 95-00
Old 07-03-12, 12:29 PM
RA010623
RA010623's Avatar
Default finally found Stainless Steel Brake Line for UFC20 95-00
I contacted Stuart over at Techna-Fit and he took care of me and send me a set of stainless steel brake line for 95+ UCF2X LS400
the line is not listed on their website but the part # LEXS-1210
more review after i get them installed
Old 07-03-12, 01:46 PM
acidfire52
acidfire52's Avatar
nice. Would like to know if they improve pedal feel at all.
Old 07-03-12, 02:54 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
interesting. techna fit is relatively well known so if these become easily available they will have basically cornered the market.
Old 07-03-12, 05:03 PM
RA010623
RA010623's Avatar
i've been using techna fit on every car i've own.
from past experience on my 05 wrx and 95 miata they both significantly improved pedal feel .
the line also have great fitment on those other applications.. i will report back on installation and fitment
i was kinda worry because the application is not listed on their website they Stuart assured me it will fit 95 LS400
Old 07-03-12, 09:34 PM
dengman
dengman's Avatar
I've used technafit before on previous cars. I suppose I should check my lines and see how they are and order some.
Old 10-06-12, 05:27 PM
bicol-ini
bicol-ini's Avatar
hi its good to hear that ss brake lines available for the 95-00 ls400, anyways how much did it cost buying direct? or are there any distributors online, (currently using technafit on my 81 celica with supra rear end)
Old 10-06-12, 06:15 PM
bicol-ini
bicol-ini's Avatar
hi maybe somebody got connection at techna fit and initiate a group buy, fo a discounted pricing
Old 10-06-12, 06:55 PM
PureDrifter
BahHumBug
only approved vendors can initiate group buys, so you should contact one of the clublexus vendors that carries Techna Fit and see if they have any interest in running a GB on the lines.
Old 10-06-12, 11:03 PM
BigLexx
BigLexx's Avatar
Couldn't come at a better time,as I'm about to replace my brake pads and rotors. Good looking out!!
Old 10-06-12, 11:15 PM
RA010623
RA010623's Avatar
just buy direct.. stuart at technifit is a great guy.
Old 10-07-12, 12:04 AM
PK_Celsior
PK_Celsior's Avatar
i though these lines would be readily available xD. I purchase my SS lines through Rotora awhile ago. I've seen significant improvement in pedal feel. how much are they through technafit?
Old 12-14-12, 12:58 PM
Shmee
Shmee's Avatar
interesting... looked online and their pricing is about $115 for all other Lexus kits.
i was trying to figure out if Supra brake lines would work with our cars, considering they have the same callipers, but this is much easier!
Searching works! haha
Old 12-14-12, 08:52 PM
PureDrifter
BahHumBug
length issue.
Old 03-01-13, 01:20 PM
RA010623
RA010623's Avatar
quick update. i just finished installing the techafit brake line
basically front and rear lines are same fitting same length.
So if you looking for stoptech or other brand just buy 2 sets of the fronts.
i think stoptech only make one Front part number
overall the brake pedal is much firmer.
installation was very easy. Only thing i had to reuse was two retaining clip on on the wheel well bracket near the hard line.
Old 03-01-13, 07:55 PM
Dranom
Dranom's Avatar
How much for the set?
ZERO5RX330
06-17-14 02:17 PM
Bradster
04-23-10 10:58 AM
AEKDBadGS4
Suspension and Brakes
08-20-08 01:36 PM
BigWaveSC
04-19-06 05:21 PM
tvd51
04-24-03 09:22 AM
Quick Reply: finally found Stainless Steel Brake Line for UFC20 95-00
