9x18 Porsche wheels
9x18 Porsche wheels
hey guys im able to buy nice set of wheels and tires for a great price. They are orig. from Porsche boxster ...front tires are 225/40R18 rear 265/35R18 ...the rims are sock porsche 18" chromed 5 bolt pattern 9x18 265/35/18 Boxster wheel ...could u tell me ifi would be able to fit them? and if yes than what do i need to do so
the bolt pattern and offset are much more important than the wheel size. In other words, they are 5 bolt design wheels but what is the exact spacing of the bolts apart from each other. If they are not the same you will have to purchase, or have made, some adaptors. The off set is in reference to how far the wheel is off set from where it is bolted to the hub. If its too far off you may have some excessive rubbing on your inner or outer fender. Post some photos and someone may be able to tell you the exact type of wheel and you can then search for the specific spec's of them.
Sent via mobile phone,
Super Moderator
Porsche wheels are 5x130 lug spacing and those 987 wheels are probably 43mm offset. You will need an adapter to mount these up. What generation LS do you have? How is the ride height on your car or the intended ride height? As far as tires and fitment, I'll defer to others.
those look like the wheels off a 996 generation 911, so like a 2000-2006 porsche. isnt the 987 the newer boxter? regardless if you can get them cheap i would pick them up and sell them again. using adaptors to install wheels is really not the best way to go in my opinion.
wheels
I have 2nd gen ls400 95 ...ride hight now is stock ...maybe down the line drop of 1-1.5 inch but that will be in quite a while ...im able to pick them up dirt cheap with good tires on it ...i think these are 50 and 52 mm ofsets ..ill find out ASAP but till then i can only guess ...thanks for your help guys i appreciate it
enginyr
Wheels, Tires & Brakes Forum
40
04-01-02 08:52 AM
