Post up your Rear muffler set-up!!! In need of inspiration!!
Old 06-26-12, 07:06 PM
RA010623
RA010623's Avatar
Originally Posted by PureDrifter
the magnaflows will sound better and probably flow better...
any particular one you would recommend?
Old 06-26-12, 07:41 PM
Dirtybrd
Dirtybrd's Avatar
I wanna see if anyone has done it and how it came out, is that so hard to understand?
Old 06-26-12, 07:57 PM
RA010623
RA010623's Avatar
here few examples googleing
Old 06-26-12, 08:01 PM
RA010623
RA010623's Avatar
magnaflow
Old 06-26-12, 09:30 PM
RA010623
RA010623's Avatar
found a setup i really like
i'm thinking of running dual exhaust tip like this but maybe a little smaller and with slant cut tip.
maybe something like this
http://www.ebay.com/itm/STAINLESS-DU...06fbc1&vxp=mtr
Old 06-26-12, 10:05 PM
RA010623
RA010623's Avatar
anyone have dual magnaflow 10428 exhaust
http://www.magnaflow.com/02product/s...=main&id=10428
Old 06-26-12, 10:39 PM
MrFuel
MrFuel's Avatar
Here is a picture of my LS400. Junction Produce exhaust
Old 06-26-12, 11:13 PM
ls400916
ls400916's Avatar
Looking towards dual tips now. Those fabulous set look clean. Scraped holes in my stock ucf20 exhaust on the way back from the BOS meet. Took it to a local muffler shop. Cut off my flanges after the cat, deleted the resonator and mid muffler, added an x-pipe and 2.25" piping all the way down. Still have the stock rear mufflers though. Looking for the right look. Amazing clearance with what's been done though.
Old 06-26-12, 11:20 PM
RA010623
RA010623's Avatar
i'm still deciding if i should keep the stock Y pipe and cut off the exhaust after the stock Y and just replace the 2nd muffer and axle back with magnaflow 10428
i want the keep my exhaust relatively quiet it's a luxury car after all
Old 06-27-12, 01:47 PM
ls400916
ls400916's Avatar
Doesn't sound like a bad idea. Actually looks good. Were you keeping the resonator? just curious. You would have to find some sleek mufflers for the mid muffler set-up though. I removed the cat flange, resonator and the mid mufflers just so the shop could tuck everything above frame level.I was scraping my mid mufflers like crazy before.
Old 06-27-12, 01:49 PM
ls400916
ls400916's Avatar
MrFuel.. where'd you pick up those rear taillight eyelids? Lookin clean. I've seen your car at driven authority before
Old 06-27-12, 03:12 PM
MrFuel
MrFuel's Avatar
Ya, I work there. The eyelids are made by junction produce. Got them from a friend that gets me all my parts from Japan.
Old 06-27-12, 08:32 PM
PureDrifter
BahHumBug
Forum Moderator
PureDrifter's Avatar
look at the exhaust layout thread in the FAQ for questions on how best to lay out your new setup.
i'm a fan of quads. I've had another set to replace the DTM-style tips ive had on the car the past 5 years but havent had the chance to go to the exhaust shop
Old 06-27-12, 11:45 PM
RA010623
RA010623's Avatar
here is the repost of the exhaust diagram i found in the faq
Old 06-27-12, 11:49 PM
RA010623
RA010623's Avatar
i wanted to keep resonator cuz i want a quiet exhaust system .
i think if you want to replace the center exhaust maybe you can replace with a resonator or CAT or maybe something like this http://www.magnaflow.com/02product/s...=main&id=10134 which you should be able to tuck it pretty tight against the body to avoid rubbing.
Quick Reply: Post up your Rear muffler set-up!!! In need of inspiration!!
