Weird Pinging/knocking unde slight acceleration
Old 06-13-12, 09:36 PM
enigma94
enigma94's Avatar
Default Weird Pinging/knocking unde slight acceleration
Hey all, i've noticed that whenever I either go from a complete stop or let off the gas and coast for a second or 2 then give it gas I get a weird pinging/knocking noise for 1-3 seconds. I cant figure out what this could be but it seems to be worse whenever its really hot outside or right after start up and the car is still a bit cold. The odd thing is that it only does it under those 2 conditions, whenever I give it a lot of gas it doesn't do it so I'm kind of stumped.
Car is a 98 LS400 with 147K
Old 06-13-12, 11:10 PM
skperformance
skperformance's Avatar
what grade gas ,
last time you changed your plugs , air filter , cleaned the throttle ?
Look at those first
Old 06-14-12, 02:50 AM
enigma94
enigma94's Avatar
Originally Posted by skperformance
what grade gas ,
Look at those first
I always use 91. I thought it might be the plugs but I figured it would do it under hard acceleration as well? I bought it with 134k and have not changed the plugs so who know the last time they were changed. Air filter is new. When you say clean the throttle do you mean the throttle body??
Old 06-14-12, 12:19 PM
Lavrishevo
Lavrishevo's Avatar
Water temp and knock sensor also come to mind.
Old 06-14-12, 09:00 PM
94ncls400
94ncls400's Avatar
Where is the location of those two out of curiosity?
Old 06-15-12, 01:57 AM
enigma94
enigma94's Avatar
The temp gauge reads the same as it always has so I dont think that would be it, and im not sure if the sensor was bad how it would create this issue. If the knock sensor was bad wouldnt it throw a CEL?
Old 06-15-12, 03:47 PM
94ncls400
94ncls400's Avatar
From what I hear, the ecm does not throw a code sometimes. I'd do a scan and see.
I was asking the location of the knock sensor and water temp sensor .
Old 06-15-12, 06:31 PM
j2b4o
j2b4o's Avatar
The CTS that causes problems isn't the one that feeds the temp to the dash. They are separate. It has a green connector I think and its up front on top. Easy to find.
jaxscuby
17
05-04-22 07:06 PM
leerocks
SC- 1st Gen (1992-2000)
03-23-12 07:39 PM
bravonext
41
08-31-10 08:20 PM
dundfaukus
GS - 1st Gen (1993-1997)
12-30-04 09:02 AM
Quick Reply: Weird Pinging/knocking unde slight acceleration
