UAS bag over on BC coils
Old 05-21-12, 05:02 PM
ZachAttack
ZachAttack's Avatar
Default UAS bag over on BC coils
I have a 2000 ls400, bc coils and UAS aerosport bags auto pilot v2. The rear works great airs up and down, however I cannot get the front to lift up. I've tried everything I can think of at this point. At most it'll lift 1/4 inch then stops.
Old 05-21-12, 05:28 PM
timmy0tool
timmy0tool's Avatar
since you have coils, why not raise the perch so the bag sits higher? also what kind of bag brackets are you running? length? when i ordered my UAS bags they specifically made the brackets for my BC coils, though i'm sure if i said megan coilovers they would be the same length as well.
also check to see if you have your preset bag pressure at the correct number. i know autopilot v2 has the ability to preset that, among other way cool features!
i have yet to install the EXACT same setup as you, minus the v2 which i am heavily considering. if you don't mind, where did you get it from?
Old 05-21-12, 06:52 PM
ZachAttack
ZachAttack's Avatar
Got a video up: http://youtu.be/3SPgWtx1FXw
I just have the aerosport plates, I'm not really sure if I'm doing something wrong. This is my first bag over install, I have done a GTI before but it had airlift struts/bags.
Car is stuck at a friends house and I really need to get this project done haha. Got the kit from Bagriders, great price but now I'm tempted to sell it : (
Old 05-21-12, 09:10 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
you need to reset the height of the lower bracket on the front coilovers.
Old 05-22-12, 05:54 AM
ZachAttack
ZachAttack's Avatar
I tried moving the bag up but when I did that I got 0" of lift. Not really sure what's going on. I'll take some photos of the set up tonight.
Old 05-22-12, 08:55 AM
LiCelsior
Retired
LiCelsior's Avatar
dont move the bag up, turn the bottom mount down.
Old 05-22-12, 08:59 AM
ZachAttack
ZachAttack's Avatar
^ so re set the bag to correct position and spin down the mount making the strut longer assembly longer?
Is it just under too much tension?
Old 05-22-12, 09:13 AM
LiCelsior
Retired
LiCelsior's Avatar
yea basically, adjust the bottom mount until ur satisfied with the amount of lift u get with the bag fully inflated.
if u had ur coils set at the same height u were static then more than likely they were too short at full lift.
Old 05-22-12, 11:10 AM
timmy0tool
timmy0tool's Avatar
when talking to UAS he told me to set the lower spring perch/bag bracket 4 inches from the top of the shock body (not the shaft). this is b/c the bag fully deflates to 4 inches and you don't want the shaft to fully compress when airing out. that means you shouldn't exceed that 4 inches.
different car but check this out.
http://www.lxforums.com/board/f140/a...r-bags-218118/
nah don't sell it, but if you do hit me up.
Old 05-23-12, 05:50 AM
ZachAttack
ZachAttack's Avatar
Worked great! Made the strut longer and it lifted right up.
Thanks guys!
VNN326
01-28-16 08:05 PM
wiliu0
Suspension and Brakes
10-17-15 03:14 AM
Patrick047
13
04-18-15 11:30 AM
LudeNsoL
02-05-12 07:20 AM
Kybball#1
04-29-10 09:11 PM
Quick Reply: UAS bag over on BC coils
