1996 ls400, new trani or new mounts??
Shutters when it drop shifts...
Have you adjusted the kick down cable to spec? Also, the IDL portion of the TPS should be checked. These are simple adjustments or replacements as suggested by multiple Lexus mechanics. I am of the school of thought that believes you start with the most simple resolutions and increase in complexity. Yet, for piece of mind, I would immediately change the fluid to ensure you are working with T IV. Then you can check it off of the list and feel good about it.
Best of luck
Best of luck
I'm going to do all of these things you have prescribed above as they seem the most plausible places to start. I am just wondering if anyone else has experienced this issue?
I have two questions though. Where can I find kick down specs and what is the IDL portion of the TPS?
Thanks, Dwaino
AlaskanLS
08-29-18 11:08 PM
RRocket
03-08-12 04:49 AM
mk7301
09-03-11 12:50 PM
1994 LS400
11-15-01 01:17 PM
1996, 96, change, differential, engine, fluid, lexus, ls400, mount, oil, price, replacement, shift, solid, transmission
