View Poll Results: Unrelated
ES 300
0%
GS 300
33.33%
LS 400
66.67%
SC 300
0%
SC 400
0%
Voters: 3. You may not vote on this poll
Control Arm Needed!
Old 05-02-12, 01:53 PM
SEANCLIME
SEANCLIME's Avatar
Default Control Arm Needed!
I recently hit a pot hole going a little too fast and bent both my front lower control arm (right), rear lower control arm (right) see diagram #10,#11. Is anyone out there selling parts for a Ls 400 years 95,96, or 97 w/air suspension? Or does anyone know where I can buy these parts used online or anywhere near south eastern Pennsylvania? I found them new on mylexparts.com but I would like to find them cheaper if possible. They where both about $100 a piece on that site.
Also does anyone know if the same parts for the es 400 or es 300 would fit my ls 400?
Or if the other model doesn't have air suspension like mine does could it still work?
SEANCLIME is offline
Old 05-02-12, 03:39 PM
midwest2
midwest2's Avatar
The front-lower arm on that site is $224. I think you can get it a bit cheaper from Sewell. I wouldn't get a used one, the bushing is likely to be shot on it. You must have hit a hell of a hole.
midwest2 is offline
Old 05-02-12, 06:39 PM
dashan
dashan's Avatar
Buy one from junk yard, press new bushing in.
dashan is offline
Old 05-02-12, 06:54 PM
mikes7ke
mikes7ke's Avatar
He has a UCF2X. From what I've gathered, the only bushings available are polyurethane. You're pretty much on you're own if you go that route, or I totaly suck at searching. I'be yet to read anything I could find worthwhile reading concerning LS400 and polyurethane bushings.
OP, $100 per arm for a new arm and bushing already pressed in is nothing. If you want something totaly unreasonable, get a UCF1X and replace front upper control arms with OEM pieces.
mikes7ke is offline
Old 05-02-12, 06:56 PM
billydpowe
billydpowe's Avatar
yep, My choice also.
billydpowe is offline
Old 05-02-12, 06:57 PM
j2b4o
j2b4o's Avatar
I don't think there is an es400 but I doubt any ES suspension works as its fwd. try rockauto I you want to try cheap aftermarket parts. Might find somethig decent.
j2b4o is offline
Old 05-02-12, 07:25 PM
midwest2
midwest2's Avatar
I bought these and will be installing them next week. I will report back on how they ride and how difficult they were to press in.
http://www.ebay.com/itm/180806209201...84.m1497.l2649
midwest2 is offline
Old 05-05-12, 06:47 PM
Luxor
Luxor's Avatar
I have what you need. https://www.clublexus.com/forums/ls4...-and-more.html
Luxor is offline
Old 05-05-12, 08:46 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
WTBs go in the classifieds. closed.
PureDrifter is offline
moat
01-12-12 02:09 PM
lowKut
05-31-11 10:35 PM
vinhtrandi
Suspension and Brakes
05-23-10 10:25 PM
Quiller
09-21-05 11:29 AM
damon
07-09-03 11:22 AM
Quick Reply: Control Arm Needed!
