help my 94 ls400
Old 04-17-12, 08:07 PM
1ciscokid
1ciscokid's Avatar
Default help my 94 ls400
Need help please.. I have a 94 ls400, every time I turn off the car and get out.. why do I keep geting a little shock from the door..
Old 04-17-12, 08:14 PM
trukn1
NELOC Mod
trukn1's Avatar
Car is just happy to see you, and wants to let you know that you have a SHOCKING personality,,. LOl!!! You have some electrical running through the door that may just be touching frame. you may have to take the inside panel off and check for loose/frayed wiring touching frame. Wiring would be for power windows, speakers, door locks as well as the courtesy light in the door. I would start to look there first. Easy enough to check.
www.lexls.com will also help you to navigate your way around this car as well.
Old 04-17-12, 09:41 PM
whit3b0y
whit3b0y's Avatar
go to an auto parts store and buy a static strap. unbolt one bolt from one of the tie downs behind your rear bumper. Install by putting the bolt back while inserted in the static strap.
Old 04-17-12, 10:57 PM
GS4_Fiend
GS4_Fiend's Avatar
It's called static electricity. Ground yourself before touching the car.
Old 04-23-12, 07:24 AM
1ciscokid
1ciscokid's Avatar
thanks ill look into that!
Old 04-23-12, 07:27 AM
1ciscokid
1ciscokid's Avatar
i will pop the door panels off..to take a look..thanks
Bretth
03-14-17 12:15 AM
Deuce_B
20
02-19-12 08:06 AM
Husker1
05-14-10 03:07 PM
sonbum1
04-05-08 03:22 PM
DriftGirl
02-27-07 08:53 PM
Quick Reply: help my 94 ls400
