Megan EZ cut coil over body
I know a big problem with the EZ series is that the backs dont go low enough for some. Since the threaded body is too long to allow for the coil collar to be screwed further in, would it be feasible to cut the threaded body so the collar can make the coilover shorter.
I was seeing if theres other options to besides lowering the preload perch down, that I can keep preload at zero and shorten the actually coilover. Besides the spring rate being too soft for the height is there any other options i can do while i save for custom coilovers? Is there any major flaws to my idea?
And another question, I know typically theres a trend for dampening settings on coilovers, right now my fronts are set at 0 dampening, **** in the middle. But what way should i go about setting my dampening properly, usually you want the backs to be soft than the front right? or vice versa?
Just a quick thought. if you dont care about the ride, it might be possible to buy two sets of front coilovers and install one of them in the rear. That way you could just slam it down to the ground. I know the fronts go super low.
