Climate control LED size?
Old 02-08-12, 06:11 AM
Sneaky82
Sneaky82's Avatar
Default Climate control LED size?
Long time lurker, first post.
I recently picked up a 1995 LS400 with 185,xxx miles and have been fixing up the little things.
So some of my climate control lights have burned out and i was wanting to replace them with these:
http://www.superbrightleds.com/cgi-b...pecs%2FNEO.htm
i just can't find what size. I have been searching on here and i think they are 3mm (T-1) but i would like to be sure before i order.
Also has anyone one used these? any downsides compared to factory?
Old 02-08-12, 09:07 AM
billydpowe
billydpowe's Avatar
it comes out very easy, take it out and look
check this out: http://www.lextreme.com/lcdtech.html
Old 02-08-12, 01:11 PM
Sneaky82
Sneaky82's Avatar
I'm talking about the twist bulbs that light up the buttons not the LCD. I wanted to hopefully replace the $9 twist bulbs from lexus with $2 twist LED bulbs from superbrightleds.com
and yes it is very easy to take apart.
Old 02-08-12, 03:08 PM
curepunx
curepunx's Avatar
I followed this tutorial and it was very helpful as well as straightforward.
Goodluck!
http://www.lexls.com/tutorials/light...klighting.html
Old 02-08-12, 03:18 PM
tenchu
tenchu's Avatar
T1.5, I suggest single LED for the 3 screen bulbs, then something larger/brighter for the buttons, single LED for the buttons is far too dim
Old 02-08-12, 03:52 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
an FYI, i'm not sure when they changed them but the '98-00 AC/Climate Controls are for sure the later NEO-Wedge hybrid style twist bulbs.
may want to crack yours open to see what kind it uses before ordering any LEDs.
Old 02-08-12, 05:02 PM
Goofaroo
Goofaroo's Avatar
I don't want to hijack this thread but I was about to post a question very similar so I decided to jump in here.
Sneaky82 is asking about a 1995 model and the material in the links that he has been directed to is for a 1990-1994 model. Is it just widely understood that a 1995 model (or my 1996) is the same as the first generation models?
What I would like to do is change the color of my instrument lights as well as my the rest of my dash lights from green to red. I don't want to convert to LED because I don't want to loose the dimming capability. Everything I find online points to information about the first gen cars.Can Sneaky82 and myself assume that ours is the same as the first gen?
On my 1996, would I just replace the bulbs with red ones?
Old 02-08-12, 06:35 PM
Sneaky82
Sneaky82's Avatar
Well i orded the T-1.5 3 normal LED and 4 SMD LED. we will see how it goes.
Old 02-09-12, 11:07 PM
VanCityLS4
VanCityLS4's Avatar
It was mentioned recently but I can't find it now. What size bulb illuminates the gear selector ?
Thx
Old 02-10-12, 12:24 AM
PureDrifter
BahHumBug
a single 74
Old 02-12-12, 10:12 AM
LexGX
LexGX's Avatar
When i changed mine out, i was told it was the t1.5 from lexls' tutorial so i ordered them but they didn't fit. I ended up having to order the neo ones. They fit but it was a very tight fit.
Old 02-12-12, 02:39 PM
PureDrifter
BahHumBug
on your....?
Old 02-13-12, 03:51 PM
LexGX
LexGX's Avatar
my bad. 94'
Old 10-09-12, 05:09 PM
dc893
dc893's Avatar
I was searching to find what size LED I need for my climate control. I was about to order T1.5 LED lights and it was mentioned that they did not fit. Can anybody tell me what size LED lights I need to get? T1.5 or NEO LED and the size?
1992 LS400
Old 05-14-13, 02:58 PM
smix
smix's Avatar
this might be a bit late but i had to figure it out too, i saw on lexls.com that it was T1.5 bulbs and it wasnt but i forced it in cause i already paid for that ****. Anyways after a year later i decided to do it properly and its NEO5-x they fit great!. if some bulbs dont turn on just rotate it 180 and put them in again, they should turn on after.
Quick Reply: Climate control LED size?
