Freeze lines but no blow
Registered User
My car ac is on lines are freezing but there is no air coming thru the vents. Ac fan is on but my blowers inside is not blowing. Mannn it is hot in the bahamas i need that bad plz help.
If the lines frozen It can because its under charge or cause the blower not blowing. First thing I'll check is the blower and if you fix it and the lines still freezing check the charge. Check the evaporator to see if they freezing too if so its dirty, but if the blower not blowing it gon freeze.
Registered User
the way I read your post, I dont think you know what you are doing either.....
none of us know what is in your head..... just what you put on paper....
so if you want help, dont bite our heads off, just try to tell all you can, AND what YOU have done to try to remedy the failure....
