How do you tighten to torque specs??
Old 10-27-11, 05:25 PM
paulwall86
paulwall86's Avatar
Default How do you tighten to torque specs??
This might sound dumb but How do you tighten to torque specs??
DaveGS4
Forum Administrator
DaveGS4's Avatar
Received 2,119 Likes on 1,293 Posts
Use a torque wrench.
http://www.craftsman.com/hand-tools-...ches/s-1305567
Old 10-28-11, 07:36 AM
deanshark
deanshark's Avatar
If you're on a tight budget, Autozone has one in thier "Loan-A-Tool" collection. ( the 20-200 ft lb) I think it's about $75, but you get it back when you return it.
Old 10-28-11, 11:44 AM
python
python's Avatar
what r u torquing? wheels, head bolts or what?..huge difference...some head bolts are torque to yield and then there is torque angle as well. if ur torquing wheel bolts then there is a sequence of events ur supposed to folow and the size of the stud determines the torque spec
Old 10-28-11, 12:14 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
what is this i don't even...
http://tinyurl.com/3tehe8a
Old 10-28-11, 12:31 PM
deanshark
deanshark's Avatar
Wow, I just learned something new about a torque wrench, thanks PD. It was about extension size and lengths. I'm not being sarcastic, seriously thanks. Google really works.
Old 10-28-11, 12:47 PM
RA40
Super Moderator
RA40's Avatar
This reminds me of that long time discussion on wrench heads who through experience can torque a bolt up pretty accurately.
Last night I got a slow leak in a tire. For some reason, the lug wrench was missing from the trunk. so I had to call AAA. He did the drill and used the typical 4 lug wrench. I came home to re-torque the bolts and 3 clicked at 72#'s while 2 others at 73#'s. I was impressed since the guy seemed to take the task so casually.
Old 10-28-11, 10:18 PM
whit3b0y
whit3b0y's Avatar
harbor frieght has a torque wrench for around 30. Accurate too. We have a torque wrench tester at work that we test all our wrenches on every morning. Ill test mine every month or so. I keep it wrapped in a towel between the drivers door and drivers seat. Just in case ;-)
bb430
03-17-15 03:02 PM
davids2k
01-12-13 12:12 AM
MIGS
Performance & Maintenance
12-16-11 01:05 PM
spooksh13
08-11-06 09:01 AM
Quick Reply: How do you tighten to torque specs??
