Did lexus and others stop selling the front strut rod bushing?
Old 12-04-11, 04:52 AM
blkstealthpaid4
blkstealthpaid4's Avatar
I just installed the ones I ordered from ebay for $50 bucks each.All that time, I had a spare bad strut rod.I can order another bushing ,press it in and send to someone who needs it.If not it is going in the gargabe.Not the best ride after the change but the clunking is gone.
Old 12-04-11, 11:46 AM
billydpowe
billydpowe's Avatar
the answer is NO
because:
I just ordered 2 from SEWELL: today and have now received them ..
File Type: doc
Old 12-04-11, 08:16 PM
sdls
sdls's Avatar
billy, your address is showing in that doc!
Old 12-04-11, 09:30 PM
PureDrifter
BahHumBug
PureDrifter's Avatar
good catch, i removed the doc for now, billy can repost after removing his info
Old 12-05-11, 03:35 AM
billydpowe
billydpowe's Avatar
thanks guys, my booboo.. I edited it out
Old 12-05-11, 04:46 AM
andyman32
andyman32's Avatar
I have found strut rod bushings (not the assembly) plenty of places. Just shopped around for the best price. Sewell has them, but ended up buying a Lexuspartsnow. I'm sure others do. Mine is a '99 so I don't know if the 1st-gen part is different and maybe harder to source.
Right now I'm looking for front lower control arm bushings. THOSE apparently have no separate part number, just a whole assembly, and after looking on a dozen or more sites I can't find anything other than the assembly. Just emailed TM Engineering to ask if they have the Daizen bushings.
Old 12-10-11, 07:38 PM
LexusMirdy
LexusMirdy's Avatar
Try ebay. You can probably find a lot of OEM items for the car
Old 12-11-11, 05:36 AM
mikes7ke
mikes7ke's Avatar
48654-50010
I think that's what you're looking for.
Nevermind I didn't see your's is a '99.
Last edited by mikes7ke; 12-11-11 at 05:39 AM. Reason: typo and not paying enough attention
Old 12-11-11, 11:54 AM
billydpowe
billydpowe's Avatar
WARNING< POLY bushings are plentiful,
but your Lexus will ride and make noise like a ford if you use them,
go OEM for that Lexus ride
Attached Thumbnails Did lexus and others stop selling the front strut rod bushing?-srb-dots1.jpg
Old 12-20-11, 04:19 PM
MellonC00
MellonC00's Avatar
cam someone post a pic or a part diagram of a strut rod and strut rod bushing? I know what a strut is but I don't know what a strut rod is....
thanks.
Old 12-20-11, 05:47 PM
PureDrifter
BahHumBug
thanks.
then you should search to find them there's dozens of threads on the topic. the strut rod design changed for the 2 major generations too.
Old 12-27-11, 09:20 AM
ACLex
ACLex's Avatar
Dont know if this helps............
https://www.clublexus.com/forums/ls4...your-ls-3.html
Old 01-23-12, 04:48 PM
504's Avatar
so what's the part number for a 1996 strut rod bushing?
48654-50010
or
48674-40051
Old 01-23-12, 05:00 PM
PureDrifter
BahHumBug
48654-50010
or
48674-40051
you want either 48674‑50052 or 48674‑50051. either should work, though i've only used the first one.
Old 01-23-12, 08:29 PM
billydpowe
billydpowe's Avatar
48654-50010
or
48674-40051
yes ; 48674-40051
1995-2000
I have ordered from Sewell and Park Place, the same part number, for my old 97, and one of my 99's, and just got a set for my 96.... Sewell was the lowest price.
Buckaroni
05-31-18 09:35 AM
kuziwk
16
03-26-11 11:34 PM
hazian23
12-10-07 01:40 AM
akxx
06-18-07 03:25 PM
blkstealthpaid4
01-05-04 11:47 AM
Quick Reply: Did lexus and others stop selling the front strut rod bushing?
