1999 Lexus Ls400 Security Problem
when i bought my LS400 it came with a aftermarket key. i don't have key-less, i have to open the doors manually. i called multiple locksmith, they come they program the key-less, the car excepts the frequency but key doesn't lock/unlock the car. Last guy told me he thinks the entire security is disconnected. Because if someone tries to open the car from inside the security doesn't go off with the horns.....i need help please
just curious I have the same problem also..how did the locksmiths tell if the car was accepting the frequency or not?
when he programs the key its locks/unlocks the doors until i close the driver side door and open it. and plus they have computers that reads if the key frequency is in the key-less entry module inside the cars computer
after programming he needs to put in the "new programmed key" in the ignition?
then how come if someone tries to open the doors from inside when the car is locked the factory alarm go off? doesn't it mean the entire security system is turned off, or the fuse is taken out?
There are 2 sides to programming the key and they are significantly different procedures. The wireless portion and the Immobilizer both need to be programmed for proper operation.
Rockatansk
20
07-16-17 01:28 AM
uzz31aus
08-18-15 07:24 AM
