LS400 Air Suspension
Old 09-10-11, 08:34 PM
Kudos57
Kudos57's Avatar
Default LS400 Air Suspension
My LS400 has suddenly dropped on both sides at the front. There is no movement at all in the front suspension - its rock solid. Rear seems OK but it's a bit hard to tell as the very low front has lifted the back, but there is movement if I bounce the rear.
If I switch the height control from NORMAL to HIGH the dash light stays on NORMAL.
HELP!!!
Kudos57
Old 09-10-11, 10:52 PM
Kudos57
Kudos57's Avatar
I've now checked all the fuses to make sure the compressor fuse hasn't blown - it's OK. I'm not sure which is the ride height fuse (car is a CELSIOR and I can't read the labels) but all fuses are in OK
Kudos57
Ceriel
20
11-05-16 07:13 PM
Kahl
08-23-12 01:34 AM
jpm3
08-22-12 06:13 AM
junkiez
02-09-11 11:06 AM
junkiez
02-09-11 10:40 AM
Quick Reply: LS400 Air Suspension
