AC problem
Old 06-03-11, 07:56 AM
mark458
mark458's Avatar
Default AC problem
OK I have a 92 LS and the AC only blows cold SOMETIMES... It has at 2k RPMs 40psi on the low and 160 psi on the high. When its only blowing cool not cold the condincer fans are not turning on but when they turn on its cold... but only on the passenger side center vent the others are just cool...
Old 06-03-11, 09:42 AM
91LS400vgb
91LS400vgb's Avatar
One possibility is that it's not releasing enough heat out of the condenser. Check to see if there are lots of leaves or debris in between your radiator and condenser. Also, spray down the condenser with a hose to clean it up and see if your performance improves.
Old 06-04-11, 04:47 PM
mark458
mark458's Avatar
didnt help.
Old 06-04-11, 09:27 PM
LEXTEK1
LEXTEK1's Avatar
I like to see about 250 on the high side and in the 40's on low when the evap is warm. High interior fan and 250/40 should be cold across the vents. Sounds like its low on freon to me. R12 still? Convert it!
Old 06-05-11, 07:20 AM
mark458
mark458's Avatar
Its been converted already. When the fans DONT kick on and its sitting at idle the numbers are 52/260. at 2k rpms its 44/180
Old 06-05-11, 07:58 AM
LEXTEK1
LEXTEK1's Avatar
When the RPM's are up, the engine driven fan is pulling enough air across the condenser to keep the head pressure down. Disconnect the temp sensor connector at the bottom of the radiator. That will force the fans on high. Solve the fan issue before you proceed. Still sounds low on freon.
Old 06-05-11, 08:12 AM
python
python's Avatar
low freon....thats why u have low pressure. is the compressor clutch
engaging/disengaging a lot?
Old 06-05-11, 08:50 AM
mark458
mark458's Avatar
Nope it stays engaged all the time unless I put it to the floor.
Old 06-05-11, 11:27 AM
python
python's Avatar
its not supposed to do that either
WolfyLS460
04-28-18 01:39 PM
mmatheny
07-21-16 12:51 PM
TTVert
08-07-15 05:09 AM
FZ6 Dude
04-01-15 07:42 AM
gbarwick
07-23-13 07:27 AM
Quick Reply: AC problem
