95 ls 400 power steering leak
Old 06-02-11, 05:24 AM
ezsls400
ezsls400's Avatar
Default 95 ls 400 power steering leak
first of how do u detect where leak is comin from??? the leak is making my altenator go out..replaced return hose but still seeing fluid. must pin point problem, money to tight to experiment...please help me....
Old 06-02-11, 06:23 AM
deanshark
deanshark's Avatar
You want us to pinpoint your leak? Not to be a **** but, how can we see where it's leaking from? It could be a number of different places that it's leaking from. Get underneath it, take the bottom engine cover off, (if you still have it) park it over night, see where the leak is dripping on the ground and look up. The highest spot where there is wet fluid is more then likely your leak. You can also look at this link, it will tell you everything you need to know. https://www.clublexus.com/forums/ls4...ing-bible.html Oh yeah, Welcome to Club Lexus.
Old 06-02-11, 09:24 AM
steve2006
steve2006's Avatar
I would buy one of these for around $3.00.
and fit it to this.
Old 06-03-11, 10:33 AM
ezsls400
ezsls400's Avatar
@deanshark...thnx...i was actually lookin for suggestions...im not mechanic savvy at all!! have done the overnight thing but dont c any drips. i kno there's a leak, just not from where...da resevoir, da pump, or da pressure line. i changed da return hose already
@steve2006 thnx for da info... and oh yea....glad to be here!!!
Old 06-03-11, 11:16 AM
deanshark
deanshark's Avatar
One of the many usual places the pump leaks, which flows onto the alternator, is the ACV valve located on the bottom of the PS Pump. Use the search button at the top of this page and put in "ACV valve" and you'll find pics and info on what to do with it. Also both of my PS pumps have leaked from the top side. If you look at #6 in this, http://www.lexls.com/tutorials/steer...mprebuild.html , that's where mine leaked. All these leaks are very common and talked about alot, ya just gotta search for it.
AzHotLS
12
09-03-14 10:49 PM
DuckDog
06-27-14 09:33 AM
BigMarty
07-27-09 02:07 PM
njes300
Maintenance
11-06-02 03:29 AM
Quick Reply: 95 ls 400 power steering leak
