R Spec Datasystem controller USG for my 92 lexus ls400 UCF11 having troubles - Club Lexus Forums
Thread Tools Search this Thread
Old 05-29-11, 04:54 PM   #1
diffusion
Default R Spec Datasystem controller USG for my 92 lexus ls400 UCF11 having troubles
I just bought a R Spec Datasystem Controller for my 92 Lexus ls400 UCF11 from Lazy but I'm kind of having troubles with it functioning. The R Spec datasystem connects directly to my stock 89290 air suspension ecu with no proplem, it works, turns on with all the options with digitals, and all the buttons fucntioning perfectly.
There's only one thing, when the datasystem is hook up and powers on my normal light on my cluster flashes consistantly about every one second with out any pause or any stop. Although I did have my switch at the rear left side trunk on instead of off and the ride height setting high or normal still didn't matter.
I've talked to Lazy and he's been a great seller to help guide me through installing and how to work the datasystem controller. I've tried taking it off and putting it back on so many times and check the plugs to be sure but still no luck.
The datasysytem seems to be working some what but not fully functional. It shows the weight on the left side when I sit in the car and when I get out of the car. Besides that it won't go up or down because the normal light in my cluster is flashing and the compressor is not pumping. Anyone have any idea or clues that may be useful will surely be appreciated thank you.
Can anyone please help me out with what I should check or do? I just replace my leaking rear left strut with the struts I bought from ae80siq so it's not leaking at all. All four struts are level and if I just plug only the stock air susp ecu everything works perfectly and the normal flashing light doesn't blink. Please help.
diffusion is offline   Reply With Quote
Old 05-30-11, 09:43 AM   #2
diffusion
Can anyone help me out here? I really want my R Spec Datasystem to be working on my car. Please someone help me out here. I just bought my car about a month and a half and i'm not familiar with air struts. And the main reason why I bought this car and sold my other ls400 that has coils and spring was for this reason to have a datasystem controller for it, which I do now but i'm having troubles. Please help.
Old 05-30-11, 10:53 AM   #3
Lazy
Lazy's Avatar
I got it from ucfjon! He might know more about this then me. I never had that problem when he put it on my car so I am clueless how to fix it..
Lazy is offline   Reply With Quote
Old 05-31-11, 11:33 PM   #4
diffusion
Come on guys anyone? Or is there a certain way that I'm suppose to hook it up or like a certain procedure that I'm suppose to do it? Let me know?
Old 06-02-11, 12:51 AM   #5
diffusion
Finally, I found the problem. The wire was cut and re-wired and had black tape over it. I took off all the place that had black taped and found that one wire was disconnected. So then I made sure the wire was connected and black taped it again and everything works great now. Easy fix, just had to recheck everything carefully.
Thread Thread Starter Forum Replies Last Post
International R-Spec Datasystems Controller ASC680 - 2001/2003 LS430 Harness Asia-H.T. LS460 / 430 / 400 / 600h Classifieds 13 04-06-12 12:45 AM
International DataSystem Rspec ASG633 Air Suspension Controller YaKuZa_GS LS460 / 430 / 400 / 600h Classifieds 1 09-21-11 10:31 PM
95 LS4OO / DataSystem ?? For the Experts B-b0y LS - 1st and 2nd Gen (1990-2000) 4 02-11-10 12:59 PM
R Spec Datasystem Air Suspension Controller ASC680 *CHEAP* racinstyle LS460 / 430 / 400 / 600h Classifieds 11 11-29-07 11:01 AM
FS: datasystems air ride controller! pRaHjeC LS460 / 430 / 400 / 600h Classifieds 3 06-05-07 03:13 PM
Tags
400, 92, button, coil, controller, data, height, install, lexus, ls, ls400, problem, spec, specs, system, wire
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
