UCF20 LS400 Brake Master Cylinder, Which is Front/Rear? - Club Lexus Forums
Thread Tools Search this Thread
Old 05-27-11, 02:14 PM   #1
Cashflo
Cashflo's Avatar
Default UCF20 LS400 Brake Master Cylinder, Which is Front/Rear?
I'm doing my ABS delete and Hydro E brake install this Saturday, I was wondering which line off the master is for the front and which is for the rear?
I've looked around and haven't found any information on it.
Cashflo is offline   Reply With Quote
Old 05-28-11, 12:44 PM   #2
Cashflo
Cashflo's Avatar
Come on, someone has to know.
Old 05-28-11, 02:11 PM   #3
steve2006
It's not clear from the exploded diagram,both pipes from the master cylinder go to the ABS block and the brake line distribution is done from there.
steve2006 is offline   Reply With Quote
Old 05-29-11, 12:24 PM   #4
Cashflo
Cashflo's Avatar
Well on my previous car Nissan 240sx S13, It has 3 fittings, Front/Middle/Rear. Front and Middle each went to a different front wheel and the rear went to a T fitting in the rear of the car. So I'm assuming that the front of the master would go to the front and the rear goes to the rear. If it doesn't work I'm just going to switch it around.
Old 05-29-11, 12:52 PM   #5
deanshark
I've never worked on these master cylinders (Never even looked at it) but in the old days on my older cars, (70s & 80s) the front pool, was for the rear brakes and the rear, which had the bigger pool, was for the front.
deanshark is offline   Reply With Quote
Old 07-27-11, 12:33 AM   #6
Cashflo
Cashflo's Avatar
I have confirmed that the fitting closest to the front of the car goes to the rear, and the other is for the fronts.
Old 07-27-11, 12:51 AM   #7
emarknot
nothing to add....just curious to the intentions.
is this on/off ebrake app without lockup cuz you controll the pressue...or something different?
emarknot is offline   Reply With Quote
Old 07-27-11, 05:12 PM   #8
Cashflo
Cashflo's Avatar
Its for a hydraulic handbrake to lock the rear wheels. I can control the pressure to minimize the amount of lock to my preference. But I was mostly looking to do an ABS delete, as ABS sucks...
Thread Thread Starter Forum Replies Last Post
CA WTB master brake cylinder k311in 2Gen GS430 / 400/ 300 Classifieds (98-05) 1 10-04-15 12:06 PM
Help on rear left wheel. ihiryu Suspension and Brakes 3 11-28-12 02:51 PM
Brake Bleeding Sequence/Brake Fluid Gator Alum Suspension and Brakes 14 04-26-09 01:22 PM
95 LS400 Front and Rear brakes locking up 64convert LS - 1st and 2nd Gen (1990-2000) 1 04-24-08 01:13 AM
Very touchy brakes after Supra upgrade PM Supra Suspension and Brakes 32 02-21-06 04:39 PM
Tags
400, 93, back, brake, brakes, change, cylinder, front, frontrear, lexus, line, ls, ls400, master, photob, rear, whats
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
Copyright © 2000-2016 Internet Brands, Inc. All Rights Reserved
