LS400 ECU Compatibility
Old 05-25-11, 01:21 PM
Privateer
Privateer's Avatar
Default LS400 ECU Compatibility
I've searched, I swear! However, I've not found a definative answer to my question. Which is, how compatible are the various ECU's from the 90-94 models, with each other? A partial answer I've seen is that the ones in the low 50xxx range are for the 90-92 model years, and then the 501xx are for the 93-94 years. Yet, that rule isn't absolute, because i've seen 93's that have in the low 50xxx range. But I'm guessing based on what I've see those that have cited their model number in the thread.
Case study: My ECU has 89661-50142 as the model number. I'm wondering how far up or down in the range I can get away with, and be assured of compatibility.
Old 05-25-11, 04:15 PM
DonCorleone
DonCorleone's Avatar
There's only 2 that will work with my 1993, Cali emissions version.
89661-50150 (my car came with this)
or
89661-50151
The federal emissions (other 49 states) seem to have different part numbers.
Then you have TRAC versions and non TRAC versions, wonder if that needs to be taken into consideration.
Oreillys or one of the other autoparts websites used to have an ECU interchange list for remanufactured ECUs for your car, but I can't seem to find it now.
In the last month trawling the junkyards I've come across a ton more of earlier model LS400's (90-92) and their ecus, but not many 93-94.
Old 05-25-11, 07:53 PM
Privateer
Privateer's Avatar
I happened to find my exact model on an auction site, and I have a bid in on it. However, there was another one for much less, but I didn't want to risk it being incompatible.
Old 05-29-11, 08:53 PM
radiohound
radiohound's Avatar
I got one out of a 93 in a yard ... it has traction control ... but when I put it into my non-trac 93, it works perfectly ...
hope this helps ..
Old 05-30-11, 11:15 AM
Privateer
Privateer's Avatar
I guess where I'm looking for answers is in the area surrounding the code numbers. Does your Trac code come close to the numbers on your original ECU?
Old 02-23-13, 06:15 AM
paulybear
paulybear's Avatar
I just wanted to add something to this thread in case some one stumbled across it. I'm working on a 90 ls400 with trac that has a non trac ecu in it. I found out the hard way after trouble shooting trac codes. Both tps sensors are adjusted correctly and are in spec, all circuits tested good from the sensors to the ecu, I also pulled the trac actuator wire connector to generate a code which it did, and that code cleared just fine, but the trac (sub-tps) codes where persistent. After four days of careful analyzation, I came to the conclusion that maybe I had a bad ecu. Found out that it was just the wrong ecu. So to recap, non trac ecu will work fine in a model with sub tps as long as you don't mind the annoying trac warning light on all the time. Paul
KoukiMonst
04-04-19 06:36 PM
jawsaw1
06-24-15 01:34 PM
Och
36
03-30-11 04:34 PM
doyo
10-11-08 03:41 AM
Quick Reply: LS400 ECU Compatibility
