Window Reset/Reprogram?
Old 05-16-11, 10:30 AM
dbaze25
dbaze25's Avatar
Default Window Reset/Reprogram?
So my battery died the other day and ever since then I can't control the passenger windows in my car from the drivers door, but the individual switches work on each door. I was wondering if there's something I need to do to reprogram the switch to work again? I remember having to do something like that on my Mercedes once but I can't find anything about it for my Lexus. Has anybody ever heard of this? Car is a 1995 btw.
Old 05-16-11, 11:18 AM
steve2006
steve2006's Avatar
I think this is correct
Turn on your Ignition.
Open your window half way down (approximate)
Press and hold the auto-up button until window closes.
Continue holding the button for a few seconds and release.
Confirm it works by testing the auto-up/down window button.
Old 05-25-11, 07:24 PM
Samoastyle
Samoastyle's Avatar
I tried that and it's not working, I've been searching for a solution and can't find it. Anyone care to direct me in the right direction? There must be a way to reset the window ecu, like a sequence of some sort
Old 05-26-11, 05:54 PM
MrGreen
MrGreen's Avatar
I've got kind of the same problem, but my passenger switches don't work. Sometimes the window will go down a inch or two but much slower. I can control the windows just fine from the drivers door. Thought it was a motor issue but than how could I put em up and down from my side. I've replaced the whole window/lock control, checked over all the wiring but they still don't work in all 3 passenger doors.
Old 05-27-11, 01:53 AM
dbaze25
dbaze25's Avatar
Sounds like we have opposite problems actually haha.
Anyway, turns out its definitely not a programming issue, because now the drivers door switches occasionally work, mostly when the car has been running for a while. Any advice?
cooperww
11-10-18 08:16 AM
beachit321
02-28-18 06:54 PM
foe84
12-27-12 05:24 PM
Leines
RX - 1st Gen (1999-2003)
05-08-12 01:22 AM
mydann
06-26-07 11:00 AM
Quick Reply: Window Reset/Reprogram?
